Exit Boundary Conditions N-S equations
Old   July 1, 2005, 20:58
Default Exit Boundary Conditions N-S equations
lavan
I am trying to solve the unsteady compressible boundary layer problem for subsonic flow using FVM. What are the outflow boundary conditions i can specify to get accurate solution. At the end of the plate still viscous effects are present. so, what are extra boundary conditions i have to mention compare to Euler equations at outflow.
Thank you.
Old   July 2, 2005, 03:32
Default Re: Exit Boundary Conditions N-S equations
Jaan Pu
the boundary conditions are solely depends on the outflow environment. solid or tranmissive maybe something you should look for.
Old   July 2, 2005, 04:10
ganesh
Dear Lavan,
A Reimann BC would have been a good option, but theoretically this is valid only for isentropic case and hence you cannot use it for an 'accurate' solution. Nevertheless you can try it out for yourself. Another option is to extend your domain a little further wherein the extended part of the plate is given an inviscid b.c after which you can use the Reimann B.C. safely.
Hope this helps
Regards,
Ganesh
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Putting Boundary Conditions in ANSYS CFX 12.1 palofpinaki CFX 7 January 5, 2015 06:51
Algorithm for coupled pde with all flux boundary conditions benk Main CFD Forum 3 December 28, 2010 06:09
Boundary Conditions for 2 d N S equations vsampath Main CFD Forum 0 October 15, 2010 14:36
