AGARD AR-303 data
Old   June 30, 2005, 15:34
Default AGARD AR-303 data
Brian
Does anyone know where to find the disks (or equivalent electronic data) that are supposed to accompany the AGARD AR-303 report? I would like to do some code validation, and this seems to be one of the standard sources. I've tried the CASI database, and there doesn't seem to be any indication that disks are associated with the report.
Thanks a lot.
Old   July 2, 2005, 15:37
Default Re: AGARD AR-303 data
ganesh
Dear Brian,
I too was faced with a similar problem sometime back and was not able to get them, so I managed to get hold of papers that made comparisons with AGARD data and extracted them out of it. If you are planning a couple or so test cases, I can help you out if you send me the cases you plan to do, but if you are looking for a large numebr of them from AGARD report, I am not sure of how to get it.
Regards,
Ganesh
Old   July 6, 2005, 14:30
Brian
Dear Ganesh,
I too have found some papers that use some of the AGARD data, but I was hoping to find the original source so that I could do more comparisons and avoid the additional error from reading the charts from journal papers. Thanks for the offer to help nonetheless.
Brian
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 08:51
export data at nodes Meenu FLUENT 1 December 30, 2011 02:24
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Help for agard wing 445.6 structure mode data Qu Kun Main CFD Forum 0 October 29, 2008 22:16
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
