CFD Software
Old   November 5, 2011, 13:44
Question CFD Software
Klaus
Marcus123 is on a distinguished road
Hi there,
I'm after a CFD program which is easy to use for 'beginners'.
I want to determine wind velocities and forces in different places of buildings (e.g. roof, walls etc.) as a result of wind, i.e. how the wind is 'distributed'.
I want to do this for different types of buildings and various constraints (e.g. how do solar panels on the roof affect the velocities and forces etc.).
The results don't have to be extremely accurate but should give me a realistic idea of what is going on.
I'm confident there is some software out there which can exactly do what I want. If you know of such a software, can you please let me know?
Many Thanks!
Klaus
Marcus123 is offline   Reply With Quote
Old   November 5, 2011, 14:47
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
All decent CFD programs will have a learning curve. I don't know of any where a complete beginner can start using it right away to obtain reasonable results. Since your geometries are not going to be that straightforward, you are going to need to learn how to make decent quality meshes. For wind engineering applications you are going to need to learn a bit about turbulence models. For flow around a building, the computational requirements will likely be significant. These are some things to keep in mind. That being said, you can probably solve your problem in Fluent, but as a beginner you should try some simpler flows first to learn how to use the software.
cdegroot is offline   Reply With Quote
Old   November 14, 2011, 15:42
Klaus
Thanks a lot!
cdf, solar panel, velocity, wind
CFD Salary CFD Main CFD Forum 17 January 3, 2017 18:09
CFD Software Recommendation 1150GSA Main CFD Forum 3 September 2, 2009 16:46
What is the optimal (economically and user friendly) CFD software for my application? Rame Main CFD Forum 0 August 10, 2009 06:30
ASME CFD Symposium - Call for Papers Chris Kleijn Main CFD Forum 0 September 25, 2001 11:17
ASME CFD Symposium Chris Kleijn Main CFD Forum 0 August 22, 2001 07:41
