Newbie: advantages/disadvantages of "penalty formulation" incompressible fluid flow
Old   October 30, 2011, 15:32
Default Newbie: advantages/disadvantages of "penalty formulation" incompressible fluid flow
bzz77 is on a distinguished road
Hello all:
I'm a chemist, interested in getting into some fluid flow modeling (e.g., advection-diffusion). I'm a newbie, so please forgive any silly questions.
Today I came across something new (the "penalty formulation") and I'd really appreciate some basic help or directions to online references in understanding (1) how it works and (2) what the advantages/disadvantages are compared to the method I'm familiar with--using conservation of fluid mass to derive an expression for the fluid pressure p and then getting the velocity profile from that.
Background:
From what I've read, using the penalty method allows elimination of pressure from the momentum equation so that the mass and momentum equations can be combined. The result is a convection-diffusion equation where velocity can then be calculated directly.
This seems kind of weird to me though. Is it a bit hokey to do this? What approximations are involved? I deal mainly with multiphase phenomena, but I so want to work on some single-phase flow too... Could it be that the penalty formulation stuff might be better suited to single-phase flow?
The first step in using the penalty method is to replace the continuity equation by:
1/e + grad u ...
I don't understand what e is. Where does it come from? The book I have just calls it a "coefficient with large values."
I guess what I'm getting at is, what ARE the advantages of the penalty method? I see that someone I respect has used it and I'm wondering why he would have chosen it over the pressure calculation method. Any advice would be very much appreciated.
bzz77 is offline   Reply With Quote
Old   November 1, 2011, 00:39
Praveen. C
praveen is on a distinguished road
I have seen formulations in which
div(u) = 0
is replaced with
eps*p + div(u) = 0
Here eps is a small number. I think the advantage is that you dont have to solve a pressure poisson equation. You eliminate p from the momentum equation, solve for velocity, and then get p as
p = -(1/eps)*div(u)
For an analysis of the error introduced in this method see
http://www.math.purdue.edu/~shen/pub/Penalty.pdf
I am told that purists frown at such a method.
praveen is offline   Reply With Quote
Old   November 1, 2011, 04:32
Hi Praveen:
Thanks a lot for your help!
It is very helpful to know that not solving the pressure equation is why this method is used, and that purists don't like it.
Thanks very much for the reference.
diffusion, finite difference, finite element method, finite volume method, penalty formulation
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Incompressible and compressible flow. Confused student. Main CFD Forum 27 March 18, 2017 13:25
Constant flow rate through a small area inside the fluid domain. robingilbert OpenFOAM 7 October 4, 2010 17:19
Turbulent flow of two incompressible fluids with the same physical properties ArneBab OpenFOAM Running, Solving & CFD 3 January 5, 2010 06:48
internal steady incompressible inviscid fluid flow Nina Shokina Main CFD Forum 0 October 21, 2003 07:11
