Solid to Fluid Heat Transfer Modelling Problem
Old   October 27, 2011, 19:55
Default Solid to Fluid Heat Transfer Modelling Problem
John Borton
bortonj88 is on a distinguished road
Hello
I am attempting to model, a solid Heat exchanger with one side set to a constant temperature and water flowing through extracting the heat energy and cooling the interior of the heat exchanger down in ANSYS FLUENT.
I have a running model, however there is no heat transfer occuring between the solid and fluid. They are in contact, and there is a quite consideerable temperature gradient.
Does anyone have any suggestions on a solution to my problem?
Thanks
JB
bortonj88 is offline   Reply With Quote
Old   October 28, 2011, 10:08
Andrew
mettler is on a distinguished road
how did you set up the volumes? you have to make sure the mesh is the same at the place where the solid and fluid meet.
mettler is offline   Reply With Quote
Old   November 14, 2011, 15:15
John Borton
Thanks for the reply.
I created the solid first, froze it, and then created the fluid by doing a boolean subtraction. They are both set to their respective states in Design modeller, (Solid/fluid)
Is there any way of checking if the nodes meet up? and is there a particular method I am supposed to use?
Thanks
JB
Old   November 14, 2011, 15:21
Andrew
I am assuming you have something like a tube-in-tube looking thing. The way I would mesh that is by picking the right edge of the outer tube and putting equal spaced nodes on that, and then the same thing for the edge of the inner tube. I would do the same for the opposite side. Then, I would mesh the right hand face (tube) and then the face of the inner tube (fluid section). Then, cooper mesh that thru the whole thing.
ansys, fluent, fluid flow, heat transfer
Heat transfer between fluid-solid domains doesn't occur Gandin FLUENT 37 August 1, 2019 03:29
Conjugate heat transfer problem hvem10 FLUENT 2 October 29, 2009 18:31
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
No Heat Transfer between two solid domains Mike ZH CFX 7 July 26, 2008 17:50
urgent: heat transfer fluid to solid marco FLUENT 1 October 28, 2005 23:17
