Kiva help needed
Old   June 13, 2005, 04:24
Default Kiva help needed
Pratap
Does some body have experience of KIVA in using this for gas turbine application.
I have 2d flow behinf triangualr bluff body. I have problem how to set the boundary condition..
Can anybody help me.
Pratap
Old   June 13, 2005, 04:50
Default Re: Kiva help needed
zaki
hi pratap,
using input file (iprep) for kiva preprocessor, you can try to divide your computational domain into several blocks. if you have a triangular body, try to arrange the blocks so that each surface of the triangle corresponds with one boundary of certain block. this boundary is set as a solid boundary (face=2.0).
i hope it helps
cheers
zaki
Old   June 13, 2005, 06:17
Pratap
I do not have any problem with my mesh. But the problem is how to set the boundary condition in running the case using Kiva 3v.
Pratap
Old   June 15, 2005, 12:28
antoine
does anyone knows the website for Kiva?
Old   July 5, 2005, 01:52
patel
http://www.lanl.gov/orgs/t/t3/codes/kiva.shtml Try KIVA3V in google and you will end up with this one as well.
mesh converter in KIVA 4 DaIN Main CFD Forum 0 June 7, 2010 13:54
Kiva 3v , cgs library. chat1983 Main CFD Forum 0 December 3, 2009 06:26
Help needed in KIVA 3v Srinivas Main CFD Forum 4 September 15, 2009 17:50
PDF - conserved scalar approach in KIVA vega Main CFD Forum 0 July 5, 2005 03:49
kiva f90 information needed Pratap Main CFD Forum 0 November 10, 2004 11:21
