Immersed boundary method for Master Thesis
Old   September 28, 2011, 05:37
Default Immersed boundary method for Master Thesis
Charlie Tan
CharlieTan84 is on a distinguished road
Dear people
Soon I would like to start on a Master Thesis about the implementation of Immersed Boundary Method on Turbulent Flows. I am more interested in aerospace applications. What do you think about this kind of Master Thesis? Is IBM applicable on aerospace or is it only good for Biofluidmechanics?
I know that my question is quite rough but any kind of comment would make me happy.
Thank you very much and have a nice day.
CharlieTan84 is offline   Reply With Quote
Old   October 1, 2011, 09:19
Charlie Tan
No idea from anyone?
Old   October 1, 2011, 11:32
leflix is on a distinguished road
Theoriticaly IBM are able to tackle all types of complex geometries problems, even in aerospace. IBM are very promising and attractive and also very elegant and smart concept. Bur for practical applications IBM are very limited. How many commercial packages use it?
Despite the fact that theoriticaly these methods can handle every kind of geometries, each time these methods have to demonstrated their capabilities in papers, authors solve the flow around a circle cylinder or a sphere. And one has to admit that in terms of complex geometries circle cylinder is the ground zero !!!
With all the respect we do have for Peskin the father of IBM, I also read on this forum that since 1972 he's still trying to improve this method. A huge quantity of papers have been published too just to try to improve this concept. So it does mean than these methods are largely perfectible. At the best second order can be achieved but in most of the cases it is first order.
I even don't know if there are commercial packages based on this concept. Most of them are based on body fitted approach. This would indicate that IBM didn't succeed to be attractive enough for commercial codes market. It is meaningfull....
To conclude, if you want to solve the flow around a square or a circle cylinder use IBM. If you want to solve the flow around an whole aircraft use body fitted approach.
leflix is offline   Reply With Quote
Old   October 2, 2011, 22:17
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by leflix View Post
I disagree with lot of what you said. I think you are not well informed.
About the IBM and aerodymics part, it is difficult to very difficult to use IBM for aerodynamics, for the reasons that most of such simulations are trying to get drag and lift forces. Since most of the IBM formulations can not represent boundary surface as good as body fitted grid, they are at disadvantage. It does not mean that it is not used for aerodynamics, some people (including me) use it.
arjun is offline   Reply With Quote
Old   October 3, 2011, 12:13
I do not see the disagreement between you and me. I'm not a proIBM or even IBM defender. I do think that body fitted approach is much better.
If you read carrefully what I wrote, I said theoreticaly IBM can tackle all type of problems, but pratical applications show rapidly the limits.
Old   October 3, 2011, 23:30
Arjun
Well there are lots of disagreements between what we two are saying.
#1 " I do think that body fitted approach is much better"
'Better' is based on situation and type of simulation required. We used almost all of commercial softwares including starccm,fluent, CFX etc and decided to dump them and now using only IBM based solvers those are inhouse codes.
If they were any better for us, we would be using them. Here are the problems with them:
a) Too slow for mesh sizes we want to run simulations at. (Amost 50 times slower than our IBM code).
b) can not handle or require too much resources to run very large simulations. (We did a calculation involving 3 billion case, try that with Fluent or StarCCM+)
#2 "I said theoreticaly IBM can tackle all type of problems, but pratical applications show rapidly the limits"
It is other way round for body fitted solvers too. Try a case with screw type compressor where two screws touch each other and rotate. Or try two complicated bodies hitting each other with body fitted approach and you will get the feeling at only premitive calculations that involve no grid movement or simple grid movements could be done with body fitted solvers.
With IBM I rotate and move things all the time, with no fuss and difficulty.
So no we are not saying the same thing.
Old   October 4, 2011, 05:04
Dear Arjun,
After your first post I thought you were pro-body fitted so that's why I said that for me there were no disagreements
But after your second post I understood you are pro-IBM.
So it seems that there is a contradiction between what you say in your last two posts.
So in one hand you say that IBM has some disadvantages compared to body fitted.
In the next post you say that IBM is much better, less time consuming, better for moving grids...
choose your side and be more clear.
I'm eagger to see some simulations with screws compressor rotating with IBM.
In which parallel universe this has been performed? ;-)
Can you simulate the flow over a whole aircraft landing with the landing gear, wheels, wings and reactors with IBM ?
Old   October 4, 2011, 06:06
Arjun
I am in side that gets my work done for my company. There is no such thing as pro IBM or pro body fitted. If body fitted solvers get the work done then use them and if IBM gets your work done then use them. There are lots of things where body fitted solvers are dis-advantage and there are places where IBM solvers have disadvantages. Trick is to know what you want to do and which will get the work done.
Plus I was responding to your points that every time someone uses IBM it is for simple geometry like cylinders etc. Which is not true because we (my company) has been using it for complicated geometries.
If you try to search around you will find that lot of good work is done with them.
PS: I have written both types of solvers and I am not partial to any of them. I like and enjoy them both.
Old   October 8, 2011, 05:22
Vincent
VincentD is on a distinguished road
Dear people
Hello there,
I have done a master thesis on a Immersed Boundary Method. First of all I would like to point out that there are different ways to immerse your boundaries. You should spend some time checking the different possibilities. Some are better for complex media, while others are better for more simple geometries.
I do not see the direct link of a Immersed Boundary Method to turbulent flows. It's a different way to apply boundaries to your flow profile, it's not a turbulent model. What kind of benefits do you expect to obtain from using a IBM in your research?
I used the IBM to determine flow profiles inside realistic porous media. It proved very succesfull. This was due to the complex geometry (which is more difficult to apply in other methods) and the large amount of forcing done by the IBM. This high forcing (and low packed bed Reynolds number) helped a great deal in terms of simulation time.
I'm no expert on aerospace problems, but I would say the benefit from using a IBM should come from complex structure. I think it is more important in those cases to pick the correct turbulence model.
Good luck and Enjoy!
Vincent
VincentD is offline   Reply With Quote
Old   January 14, 2015, 06:56
Default Thesis
javad rahmannezhad
javad.rahro is on a distinguished road
Hi.
I have found a thesis in your subject. I think it will help you.
http://www.math.rug.nl/~veldman/Scri...erTechWisk.pdf
javad.rahro is offline   Reply With Quote
Old   January 14, 2015, 15:01
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Some papers on the validation of PowerFLOW that uses something similar to immersed boundaries:
http://exa.com/web_support_2012/exa_tech_pubs.html
lovecraft22 is offline   Reply With Quote
Old   June 15, 2018, 08:28
Default immersed boundary
  #12
Ben 017
Ben UWIHANGANYE is on a distinguished road
Hello
May you help to develop an immersed boundary algorithm in OpenFoam which i can use to simulate a flow past an oscillating cylinder?
Please help to get that code if you can Or share me the document that can help to come up with mine in OF.
I would appreciate!
Ben UWIHANGANYE is offline   Reply With Quote
implementation of the Immersed Boundary Method mi_cfd Main CFD Forum 19 April 24, 2019 02:24
Immersed boundary method (IBM) vs Dynamic meshing tomyangbath Main CFD Forum 5 April 17, 2009 04:02
Immersed boundary method with momentum forcing Fuka Main CFD Forum 1 February 6, 2006 04:46
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
