June 3, 2005, 11:28 |
Pressure oscillation in time
Hi all,
I got a result from 1D gas-liquid flow computation that the pressure at interface oscillates in time. Is the phenomenon right? Could someone explain the phenomenon if it is right? Thanks in advance! |
June 4, 2005, 07:20 |
Re: Pressure oscillation in time
I have a similar problem (please see my question and discrition on the StarCD User Forum "oscillations 1D3D coupling GT-Power/StarCD" dated 29.th may.05. No, I think this oscillations are not right. That's a problem with the 3D-CFD-Software in general. I am seeking for good advice too. If you got one please let me know. |
June 5, 2005, 04:14 |
It is said that the phenomenon is non-phisical and the pressure error is produced due to the interface caputuring method. Interface tracking method will not produce such error.
But i am not clear the details. |
June 5, 2005, 16:35 |
Yes that's right. I don't know "interface tracking method", but it is an idea. In the mean time I have thought about the problem. In my case dependend on time I got very high and than very low pressure gradients. I use k eps tubr-model, and that could be a problem. I adjust the y+ cells to the recommanded values for my high speed flow, but in that time when the flow speed is low, the turb modell don't work correctly. A remedy is to use 2 layer models in that regions, so we can erase the error from the log wall law.
directMapped problem | panda60 | OpenFOAM Bugs | 4 | July 8, 2010 11:23 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 05:35 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 16:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
