Determining cell neighbours on unstructured grid
Old   September 24, 2011, 11:52
Default Determining cell neighbours on unstructured grid
orxan.shibli is on a distinguished road
Hi all.
I want to know is there an efficient way of determining cell neighbours on unstructured grid other than the way in which nodes of (say) hexahedra compared one by one. I mean,
hex_1 : node_1, node_2, node_3, node_4
hex_2 : node_5, node_6, node_7, node_8
if hex_1 and hex_2 have 3 nodes in common then they are neighbours.
So is there a better way?
orxan.shibli is offline   Reply With Quote
Old   September 24, 2011, 13:50
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Well, i think it depends on which kind of information you have. In a cell-based solver i think it's much more efficient to deal with faces. In fluent .msh files you have the following kind of information:
nodes:
x1 y1 z1
x2 y2 z2
xn yn zn
faces:
nf1 n_1 n_2 ... n_nf1 c0_f1 c1_f1
nf2 n_1 n_2 ... n_nf2 c0_f2 c1_f2
nfm n_1 n_2 ... n_nfm c0_fm c1_fm
where there are n total nodes, m total faces and for the j-th face the total number of nodes is nfj
In this kind of file you have, for each face, the two neighboring cells (c0_fj c1_fj). Hence, to obtain the information you're looking for, you just need to invert such relationship (once for all). This can be done by allocating an array like:
f1_1 f2_1 . . . fk_1
f1_2 f2_2 . . . fk_2
f1_s f2_s . . . fk_s
where each row is relative to a cell of the grid. Of course not all the cells will have the same number of faces, so some memory could be wasted.
the array is built by a single loop over the faces and, once you have it, you can retrieve the neighbor information trough the 2 previous arrays.
If you have a node based solver, this is probably not going to work. In that case you can find some information on the book:
R. Lohner: Applied CFD Techniques. An Introduction based on Finite Element Methods. Wiley, 2nd Ed.
P.S. I can't think of hexas made up by 4 nodes and sharing each other only 3 nodes. I would change these numbers in 8 and 4 respectively... or maybe hexas in tetra.
sbaffini is offline   Reply With Quote
Old   September 24, 2011, 19:00
Method is cell-centered. Meshing program is GMSH. The file is msh file. Something like this:
-total number of nodes -
-total number of elements -
node_1 x y z
line_1 node_# node_# (these lines belong to boundary only!)
triangle_1 node_# node_# node_#
tetra_1 node_# node_# node_# node_#
Thats all.
Old   September 25, 2011, 06:20
sbaffini's Avatar
Paolo Lampitella
I really suggest you to read the book mentioned above, which has algorthmic examples to treat this specific problem. Nonetheless, in this case, you are right: the only way is to check for common nodes as this is the only information you have.
Old   September 25, 2011, 06:29
Thank you very much for answering my questions.
unstructured neighbour
unstructured grid problem jack Main CFD Forum 3 September 18, 2008 04:55
2D unstructured Grid prapanj Main CFD Forum 4 March 15, 2008 18:01
help with Intro to unstructured grid mc Main CFD Forum 1 June 8, 2006 14:36
Unstructured grid generation philip Main CFD Forum 2 August 16, 2005 10:28
Unstructured Grid Generation MSc Marcio Aredes Main CFD Forum 3 April 7, 1999 04:40
