definitioon of total pressure with k
Old   June 1, 2005, 17:51
Default definitioon of total pressure with k
Carl H.
I am confused about the definition of total temperature and total pressure in a turbulent flow with non-negligible kinetic energy of fluctuation k.
I use an isentropic law to define the total pressure :
T0 = T + V**2/(2Cp) + k/2(Cp)
p0 = p*(T0/T)**(g/(g-1))
but this gives me strange evolution of total pressure (increasing total pressure). Can you enlight me on this subject ?
Thanks
Carl
Old   June 3, 2005, 13:33
Default Re: definitioon of total pressure with k
Mani
You are most likely looking for the Reynolds averaged total temp and pressure, right? Be careful with your definition of the RA total temperature. If you are solving for compressible flow, one of your governing equations is the energy equation. If that's the case, you should actually have the total energy (which includes k) already available as variable. Simply define the total temperature by use of the total enthalpy which you get from total energy and pressure.
In any event, to validate that your result is consistent, verify that total temperature does not change in time, unless there's work being done. What kind of flow is it?
Old   June 6, 2005, 09:05
Default Re: definition of total pressure with k
Carl H.
Thank you for responding
You're right. I'am looking at the RA total temperature and pressure. The flow is a stator of a compressor.
The total temperature is evolving correctly but not the total pressure which diminishes in the region of important value of k and then growes again. Is there a different definition of the total pressure that includes the kinetic energy of the fluctuation ?
Old   June 6, 2005, 14:38
Mani
There is only one definition of the total pressure.
I can imagine mixing to lead to redistribution of total energy. What you should check is that the average total pressure on the exit plane is lower than the average total pressure at the inlet, while exit and inlet average total temperatures must be the same in case of the stator. If there is anything wrong with the pressure you will see discrepancies in other flow quantities (e.g. total temp) as well. If not, your solution may simply not be converged.
Old   June 7, 2005, 04:59
Carl H.
I will check that.
Thank you for your help.
Static Pressure, Total Pressure ufechner FloEFD, FloWorks & FloTHERM 5 March 2, 2015 08:56
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
Choked Nozzle : BC using Total Pressure CSinesi OpenFOAM Pre-Processing 0 September 1, 2009 07:09
total pressure in CFX Atit Koonsrisuk CFX 0 January 1, 2005 06:46
Total pressure in a laval nozzle Sohail Ahmed FLUENT 0 May 19, 2004 06:28
