problem in solving such an equation
Old   May 26, 2005, 12:44
Default problem in solving such an equation
R
Hi, I have problem in solving such an equation
dy/dt=u(t)-S(r)*[1+(dy/dr)^2] where u(t)=U[1+Vsin(w*t)]
We are solving for y(r) and U is an constant =37, V >1. S(r)=S*(r-a)^(1/3) and S is also constant =3.33.
Follwing time depedent boundary conditions is used.
dy/dt=0 if u(t)>=S(a) dy/dr=0 if u(t)<=S(a)
I do not have problem when I solve this equations when V<1. Also I do not have problem when S(r)=S even if V>1.
Please help me thanks
Old   May 27, 2005, 01:48
Default Re: problem in solving such an equation
harish
What kind of numerical scheme are you using to solve the problem ?
-Harish
Old   May 27, 2005, 04:25
R
Actually I have used CN, Fully implicit and expilcit with back differencing and central differencing schemes.
Old   May 27, 2005, 06:01
Tom
Have you tried to write down the analytic solution - your pde is only first order so you can write down a general expression for the characteristics - from which you should see the source of your problem!
Also isn't S(a)=0 your boundary condition so that dy/dt = 0 on r=a (I assame r=a is the boundary from your notation).
Old   May 27, 2005, 08:04
R
I have tried the analytic solutions of such equation. The analytic solution is only possible for the case of V<<1. But the case of V>1 analytical solution is wrong.
Can you give me examples how can analytical solutions helps in such case.
Yes you are write about the boundary condition. R
Old   May 27, 2005, 08:49
Tom
I'm not sure what you mean by the analytic solution being wrong - unless you mean you tried to obtain a series solution in V<<1? Otherwise the (correct) analytic solution cannot be wrong since it is the solution to the equation!
What I meant by anaytic solution was that you can reduce your pde, using the method of characteristics, to a set of odes for
dt/ds, dr/ds, dy/ds dp/ds and dq/ds where p=dy/dt, q=dy/dr and s is the variable along the characteristic.
The analytic solution helps for two reasons:
(1) It gives something to test your numerics against and
(2) If there is a problem with the existence of the solution (i.e. finite time blowup) then you will be able to see why and in what parameter regions it happens.
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 14:52
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
