STANDARD TEST CASES FOR CFD-CODE VALIDATION
Old   June 18, 1999, 12:29
Default STANDARD TEST CASES FOR CFD-CODE VALIDATION
PRAVEEN CHANDRASHEKAR
I am looking for experimental or numerical benchmarks for cfd code validation, like flow over NACA-0012. Some of the standard results are from AGARD and GAMM. Can anybody tell me where I can get these data?
Old   June 18, 1999, 13:16
Default Re: STANDARD TEST CASES FOR CFD-CODE VALIDATION
Hongjun Li
There are several ways to test CFD codes. first you may test the code's structure (numerical model):
Using circular cylinder (2-D) or sphare (3-D) to run low-speed inviscid flow. Then look at the contour plots. Does the code give you symmetric flow parten in the upper and lower sides? More importantly, the up-stream and the down-stream? (Believe me, not all code can pass this test.) From there you can determine if your numerical structures (boundary conditions, bugs, numerical dissipation treatments, etc.) are Okay or not. If the code does not give reasonable symmetric flow in upstream/downstream, it is possibly because of an bad wall boundary condition, or too much numerical dissipation. If you don't get symmetric flow in upper/lower sides. there may be problems in you far-field boundary conditions. Then you can test the math model: Using any smooth shaped body with a sharp trailing edge. Run inviscid flow and look at the total pressure distribution. You know what you should get from the code. The last step is to test the physical model (viscous effects, ability to catch separation. if compressible code, ability to catch sharp shock waves, etc.) You may find some test data to compare with.
HJ
Old   June 18, 1999, 14:38
Hongjun Li
For test cases, you may try to get "Test cases for inviscid flow field method" by Yoshihara and Sacher, AGARD-AR-211. (1985).
Old   June 18, 1999, 14:42
Hongjun Li
For test cases, you may try to get "Test cases for inviscid flow field method" by Yoshihara and Sacher, AGARD-AR-211. (1985). and "Airfoil RAE-2822-pressure distributions and boundary layer and wake measurements" by Cook, McDonald, and Firmin, AGARD-AR-138, (1979).
Old   November 9, 2009, 01:54
Shu-xin Cui
xinboy is on a distinguished road
Hi,Li!
Could you send me the reference “Test cases for inviscid flow field method” AGARD-AR-211?
I can't achieve this paper from NATO.
Thank you!
email: cuishuxin1234@yahoo.com.cn
xinboy is offline   Reply With Quote
Old   November 9, 2009, 10:31
Default dataBase for CFD code validation
CFDtoy
CFDtoy is on a distinguished road
Hello Praveen,
Check this out
http://ercoftac.mech.surrey.ac.uk/
/CFDtoy
Originally Posted by PRAVEEN CHANDRASHEKAR
;3542
CFDtoy is offline   Reply With Quote
Old   November 9, 2009, 11:21
Talking ask for
Shu-xin Cui
Originally Posted by CFDtoy View Post
Hello Praveen,
Check this out
/CFDtoy
I have browsed the web you gived. It is very perfect.
Do you have the paper "Test Cases for Inviscid Flow Field Methods" I mentioned before ?
Old   February 8, 2011, 12:25
kostas
pankos is on a distinguished road
Can you give me this paper:
AGARD AR-211, “Test Cases for Inviscid Flowfield Methods,” May 1985
I cant find at internet. Thanks..
pankos is offline   Reply With Quote
Old   September 19, 2018, 06:01
Question AGARD Report inviscid
João Lourenço
JPBLourenco is on a distinguished road
Hi to all community
Some one have find this AGARD report, AGARD AR-211, “Test Cases for Inviscid Flowfield Methods,” May 1985, that can send to me? I leave here my email: jpblourenco@gmail.com.
Thanks
João Lourenço
JPBLourenco is offline   Reply With Quote
How to find standard store-seperation test case? peter.zhao Main CFD Forum 6 March 6, 2015 12:31
LES - standard test cases? Mario Main CFD Forum 2 October 14, 2004 03:48
Standard CFD test cases? Damon Qualski Main CFD Forum 1 April 10, 2003 15:10
test cases for 2D boundary layers roxana Main CFD Forum 0 April 13, 2002 10:25
Test Cases for Turbomachine Code Validation Apurva Shukla Main CFD Forum 7 August 12, 1999 14:10
