Help: IC engine fan design
Old   May 24, 2005, 10:28
Default Help: IC engine fan design
Sigan
Can anyone plz help me in designing a IC engine cooling sytem?
1.what is the mathematical relation between Radiator FAN speed and output...
2.Required fan output is 235 cubic meter /min.
Air flow resistance is 40 mm of water. what is the required fan Diameter...???? without disturbing water pump i want to increase the efficiency of cooling system...whats the realtion between fan diameter and output of air..
urgent help plz....
Sigan
Old   May 24, 2005, 19:40
Default Re: Help: IC engine fan design
arm
Post also to
http://www.eng-tips.com/threadminder.cfm?pid=71
Cooling fan design algorithm Program Megatron Main CFD Forum 3 April 15, 2011 16:56
A CFD analysis of a Turbo fan engine eleazar Main CFD Forum 1 December 28, 2010 11:40
reg-Classical method of axial fan design ramamoorthyramanan Main CFD Forum 0 June 25, 2010 01:45
Help me design a conv-div nozzle for race engine! MaxCFM Main CFD Forum 29 May 30, 2009 19:11
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
