Finite Difference on unstructured grids ?
Old   August 30, 2011, 17:41
Default Finite Difference on unstructured grids ?
DoHander is on a distinguished road
I've encountered an interesting passage in the book of Ferziger and Peric about the possibility of using "finite difference" discretizations on unstructured grids. I'm curious if someone has tried this approach.
At a first look this could be done by fitting a polynomial on a set of points surrounding the point of interest (for a triangular grid these points can be the neighbour points).
Do you think this approach can be applied for transonic flows with shocks ?
Do
DoHander is offline   Reply With Quote
Old   September 4, 2011, 08:12
cfdnewbie
cfdnewbie is on a distinguished road
I haven't done this yet, and I can't remember ever seeing people at conferences and such doing unstructured FD.... I guess it would lose most of its simplicity if you would have to fiddle around with building polynomials in arbitrary space.... from my opinion, if you have to do that, why not go the rest of the way and do FE?
cfdnewbie is offline   Reply With Quote
Old   September 5, 2011, 18:35
I think you are right about losing some of the simplicity of the formulation if you apply FD on unstructured grids.
I wonder if you could arbitrarily increase the order of precision of a scheme on unstructured grids the way you can on structured grids ... I suppose a better way to achieve higher precision will be to use DG FEM schemes or spectral methods.
Do
Old   September 5, 2011, 18:49
cfdnewbie
Do
I guess you can indeed increase the order in an unstructured setting with FD - I guess it just becomes too messy and convoluted to be effective....
in my part of the community, people only use FD on structured grids with medium order (6, 8, sth like that) to do research into basic turbulence and transition. As soon as the geometry gets a little bit more elaborate, they turn to DGFEM or DGSEM.
Cheers,
newbie
Old   September 6, 2011, 15:28
irfan khan
imbaasat is on a distinguished road
Do
finite difference use Taylor expnsion series to find out difference scheme. it needs orthonal grid. so "unstuructured mesh" not usually orthogonal . so not valid for implementation fd on "unstructured....
imbaasat is offline   Reply With Quote
Old   September 6, 2011, 16:05
cfdnewbie
Well, not fully true. You can construct an orthogonal basis in space, and then interpolate your unstructured nodes.... FEM does that for example. So it's possible, just not in an easy or efficient way for FD- as far as I know!
cheers!
Old   September 7, 2011, 03:45
K
carambula is on a distinguished road
Do
You may search by 'wlsqr scheme' and for certain reason they make it finite volume, probably to account for conservation, but finite difference also possible. I also saw an application of the method to transonic flows on recent conference, they used no any mesh, just distribution of points. And i also saw a paper using radial basis functions instead of polynomials. I may refind those links if you are interested.
carambula is offline   Reply With Quote
Old   September 7, 2011, 08:45
@carambula
Thanks,
I think you are talking about meshless (or mesh free) methods which are a bit different from what is suggested in Ferziger and Peric's book. (Actually they are also talking about mesh free methods, but this is a separate paragraph and a different idea than applying FD on unstructured grids.)
Do
Old   September 7, 2011, 15:35
K
@DoHander
maybe it's 'mimetic finite difference'?
Old   May 21, 2023, 21:58
Default It is very much feasible
samymukadi is on a distinguished road
It can be done, and it is efficient indeed. It's simple and straight forward. In FE stiffness matrix is built, but FD you build the differential terms directly.
I use it this way too.
samymukadi is offline   Reply With Quote
[Other] OpenFOAM - structured or unstructured Grids ? thomasduerr OpenFOAM Meshing & Mesh Conversion 22 November 25, 2018 00:18
References for the finite volume method on unstructured grids old newbie Main CFD Forum 1 April 26, 2011 00:53
Finite volume solution methodology for Unstructured grids Dhileep T K Main CFD Forum 1 May 4, 2010 07:38
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 23, 2005 00:49
Finite Difference on Unstructured triangular meshe Dinesh Godavarty Main CFD Forum 0 March 9, 2004 01:35
