August 3, 1998, 13:49 |
CFD in C or C++
Hi there,
As I just have started programming CFD in C++ I am asking for some references or sites on the net about numerical recipes or CFD codes in C++. My thinking is that it is much easier to look at codes which are already written in C++ than translating existing Fortran codes. Many thanks in advance for your help and cooperation. Thorsten |
August 3, 1998, 18:25 |
Re: CFD in C or C++
Are you planning to code the solver in C++? If so, is this to examine C++ capabilities, to examine CFD algorithms or to develop a code to examine physical problems? I suspect it is not the latter if you already have exisitng Fortran codes?
Peoples experiences of developing solvers in C++ and the reasons why some are moving from Fortran to C++.(and why some have moved back to Fortan again) may make an interesting discussion topic. I would exclude pre and post processors because the reasons for coding those in C++ are compelling. In answer to your question - there is quite a lot of C++ solver code out there. For example - diffpack is fairly well developed example at http://www.nobjects.com/Products/Diffpack - overture (built on A++/P++) is another good example http://www.c3.lanl.gov/%7Ehenshaw/Ov.../Overture.html - the object orientatated numerics page has a lot of links on the subject: http://monet.uwaterloo.ca/blitz/oon.html |
August 4, 1998, 21:37 |
Re: CFD in C or C++
My son's idea was to look for a translator program between Fortran and C++ or C. Somebody must have done just that when C and later C++ were created. If you like to use a specific library of classes, then you need to get familiar with that particular library first.
STAR-Works : Mainstream CAD with CFD | CD adapco Group Marketing | Siemens | 0 | February 13, 2002 12:23 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 11:44 |
