May 19, 2005, 06:49 |
Physical meaning of Y+?
Hi all, I try to figure out what's the physical meaning of Y+ from many explanation. But I still cannot get it! Can somebody explain for me, thanks!
May 19, 2005, 18:35 |
Re: Physical meaning of Y+?
Y+ is a non--dimensional parameter, based on which different regions near a wall boundary are divided. For example, a location of y+ = 5 will lie in the viscous region independent of the flow parameters (fluid, velocity, length of domain, etc.)
May 19, 2005, 20:53 |
Hi agg, thanks, Do you mean the Y+ is only an index to determine whether it is located inside the boundary layer or not? Then what's the Y+ range for boundary layer? thanks.
May 19, 2005, 22:45 |
To learn more about ranges, refer, "Computational mechanics and Heat tranfer" by Anderson, Tannehill and Pletcher.
May 20, 2005, 01:27 |
Thanks agg for your response.
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Physical meaning of pressure in pressure eqn | dontknow | Main CFD Forum | 2 | August 30, 2010 10:12 |
Physical meaning of this velocity pressure correlation? | huijingmm | Main CFD Forum | 0 | January 22, 2010 00:20 |
Divergence of Tensor (physical meaning) | John | Main CFD Forum | 1 | May 22, 2008 15:48 |
The physical meaning of CO of outlet? | ZHANG ZHIQIN | Phoenics | 1 | December 3, 2002 23:30 |
