Writing Blockstructed - HexMesher: Create O-Grid.
Old   August 22, 2011, 10:17
Question Writing Blockstructed - HexMesher: Create O-Grid.
zampa's Avatar
zampa is on a distinguished road
Hy Guys.
I´m working in my free time on a blockstructed hex-mesher, like the Icem-Block mesher.
I know a little bit of hex-meshing, and thought that it should be possible to write a interactive hex-mesher (I´m leaving apart the geo-handling - proyection. I know from others could do that job), and now I am doing this as a hobby. It started some weeks ago, as a general idea, and now it´s becoming a real form.
In this first release, transfinite interpolation (TFI) will be used. Maybe with edge length weight. A wrote a standard TFI interpolant, and it works well. Edge link, and so on although works. The big rest is to handle the block-data structure.
OK.
The QUESTION is: How would you define the points of an O-Grid?????
To make it easier, think about a block with corner vertexes P0, ..., P7. I want to create a O-Grid with FACES on the face P0, P1, P2, P3 and the face P4, P5, P6, P7. (opposite faces)
How are the 8 O-Grid points defined? I´ve got some ideas, but I don´t know exactly what Icem does, or how Icem calculate the O-Grid vertexes.
Any idea?
Thanks,
Zampa.
zampa is offline   Reply With Quote
blocking strategy, blocking technology, hexa mesh, hexahedral mesh
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 15:18
How to create peristicaltic flow with grid deform. Anthony Main CFD Forum 0 August 30, 2006 04:06
2d CGNS grid for use with ensight zonexo Main CFD Forum 0 May 16, 2006 22:37
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
