Mass flow rate through each cell
Old   August 21, 2011, 04:18
Default Mass flow rate through each cell
Babakjingo is on a distinguished road
Dear All,
In the attached figure, totally 1.6 kg/s enters the cavity from the bottom. Left and right sides are closed. Mass flow through each face is indicated. Conservation of mass in all cells is satisfied. Total mass flow through each cell, calculated from the summation of entrance masses to each cell is also depicted in red ovals (e.g. the top right cell is 0.1+0.3=0.4). The problem is that this does not really show the exact mass flow through each cell. Because the summation of all ovals will be greater than the total mass flow entering the cavity. I say the summation of all mass flows through each cell should equal the entrance mass flow. Is it right? In that case how can I resolve this problem? I need to find the mass flow rate going through each cell accurately.
Babakjingo is offline   Reply With Quote
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 10:58
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 03:42
Mass Flow Rate is not converging destgir448 CFX 5 December 11, 2010 06:55
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 10:29
How are the mass flux and mass flow rate defined? Miles Siemens 2 November 7, 2002 09:45
