#21 | |
Michael Moor
Rep Power: 14 ![]() |
On one quick note about the initial guesses, which initialise the solution... at the moment, I have a guessed pressure field p* which is a linear distribution from west to east, i.e. 10-8-6-4-2-0, and I have also set the intial velocity field u* equal to the inlet vlaue, and v*=0. Anderson suggests putting in a velocity spike in a v control volume to create a 2D flow also. If i set the u velocity field to zero (i=3 onward to i=NI-1), my outlet b.c returns NaN, and the solution fails due to this piece of code: u(nX,2:nYp-1)=u(nX-1,2:nYp-1); % First extrapolate values from the domain u(nX,2:nYp-1)=u(nX-1,2:nYp-1)*sum(u(2,2:nYp-1))/sum(u(nX,2:nYp-1)); % This multiplier is the mass in divided by the mass out, which ensures continuity So I guess the question is, do i assign velocity values that correspond with p*, or is it just sufficient that the u-velocities be non-zero? This is all much appreciated and I am making more progress than I have in a long time! Best Regards, Michael |
#22 | ||
HouKen
Rep Power: 15 ![]() |
As for NaN problem, I guess, because you applied 0 to all u velocity as initial guess, so when you apply Quote:
As far as I know...pressure initial guess is not so crucial problem. good luck |
#23 |
Michael Moor
I assume then that this is what you mean:
%% Apply Boundary Conditions boundary_conditions(); %% Solve for u* [ustar, diJ]=u_momentum(); %% Check continuity again % u(nX,2:nYp-1)=ustar(nX-1,2:nYp-1); % First extrapolate values from the domain % u(nX,2:nYp-1)=ustar(nX-1,2:nYp-1)*sum(u(2,2:nYp-1))/sum(u(nX,2:nYp-1)); %% Solve for v* [vstar, dIj]=v_momentum(); %% Solve for p' [pdash] = pressure_correction(diJ, dIj); Where now I have used the values of u* along i=NI-1, whereas in the boundary conditions, I had used the values of the initial guess. |
#24 |
Mostafa Ghadamyari
Rep Power: 13 ![]() |
Thank you very much for your notes!
My cavity code wasn't working till I used your suggested relaxation factors! And now it is working like a charm!! |
Lid-Driven cavity flow with SIMPLE method | luckyxu | Main CFD Forum | 6 | November 9, 2011 07:17 |
[snappyHexMesh] Some tips for Snappyhexmesh required | basilwatson | OpenFOAM Meshing & Mesh Conversion | 3 | December 9, 2010 02:53 |
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 10, 2010 01:47 |
Help me on SIMPLE | L. Aouanouk | Main CFD Forum | 6 | April 17, 2003 05:08 |
flow over a 2D cyl using SIMPLE | T | Main CFD Forum | 1 | January 27, 2001 07:32 |
