August 18, 2011, 15:18 |
Very small residual
Rep Power: 15 |
Hi everyone!
For common residual definition which is, r = b - A*y I get a very small value even at the beginning (about e-5). So I'm not sure how I can set a criterion of convergence. Waiting your precious answers. |
August 18, 2011, 16:07 |
Ertan Karaismail
Rep Power: 17 |
One option could be using normalized value for setting convergence criterion;
Rn_i=R_i/R_1 < tolerance where, Rn_i= normalized residual from the ith iteration R_i = residual from the ith iteration R_1= residual from the 1st iteration (generally max residual) |
August 18, 2011, 16:37 |
Rep Power: 15 |
Mr. Ertan
Thank you. But in this case what should be the proper tolerance? How can I be sure that, chosen tolerance is enough for accurate results? |
August 18, 2011, 17:03 |
Vieri Abolaffio
Rep Power: 17 |
you would need to check at the history of some physical quantities of the flow plotted vs the number of iteration. for example lift, drag, heat transfer, etc...
August 19, 2011, 11:40 |
Ertan Karaismail
Rep Power: 17 |
That depends on how much accuracy you need. For unsteady flows, it should be safe to can pick a tolerance (convergence criterion) of 0.001 or less for the normalized residuals. For steady flows, I would suggest setting the convergence criterion to a very low value, such as 10^-10. This way you could minimize the iteration error in your calculations. (If you plot residuals, you should be able to see them level off (flatten) after a while).
HTH |
residual, small |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
