What is the Difference between Re=0 and Re=0.01 in Simulation of Viscoelastic Flow
Old   August 16, 2011, 11:12
Question What is the Difference between Re=0 and Re=0.01 in Simulation of Viscoelastic Flow
Xingyuan Chen
andreachan is on a distinguished road
I have a question for quite a long time. When people simulate viscoelastic flow, they usually do the simulation at Reynolds Number Re=0, in order to simulate the creeping flow. However there is no physical meaning for Re=0, except that the velocity is 0. But when the velocity is 0 then actually there is no 'Flow'.
So why people simulate Re=0?
Why not do the simulation for Re=0.01 or smaller instead of Re=0? Is there great difference between the results of Re=0 and Re=0.01?
Thanks for your reply in advance!
andreachan is offline   Reply With Quote
Old   August 16, 2011, 11:26
Xingyuan Chen
BTW, when people simulate the case for Re=0, they just neglect the convective term in the momentum eqn.
Old   August 17, 2011, 04:11
Xingyuan Chen
one difference is, when we consider the elastic number E=Wi/Re, where Wi is the Weissenberg number, then Re=0 and Re=0.01 are great different. But the problem is the elastic number can be also calculated by E= viscosity*relaxation time/(density*length*length).
Old   August 18, 2011, 05:43
Xingyuan Chen
still need help
thanks
Old   August 9, 2012, 06:40
Amin Shariat KHah
amin144 is on a distinguished road
some models can't be used for Re=0 or Wi=0 because of being this numbers in denominator.
after this, Re=.000001 is creeping flow and in viscoelastic viscous forces ( they are dominant in creep flow even for newtonian) are very important.
amin144 is offline   Reply With Quote
Old   November 28, 2012, 13:14
Xingyuan Chen
Could you please give me some examples that can not be used for Re=0?
Old   November 28, 2012, 17:04
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Re=0 means simply that you are assuming:
Re * (du/dt + div (u u) + grad p') = Lap u = 0
this is more a mathematical assumption than a physical condition
FMDenaro is online now   Reply With Quote
