breakup models
Old   May 11, 2005, 05:36
Default breakup models
kiao
Regarding Fluent's TAB break up model and Wave breakup model, I read that the resulting drops are calcuated by a distribution function... is that correct? How does Fluent calculate the new droplet? Do the models allow for it? I hope that makes sense, I just started learning Fluent this year.
Old   May 11, 2005, 14:47
Default Re: breakup models
Sachin
1. The drops should be calculated from a distribution based on the SMD or the mean size that Fluent is using.
2. The traditional way of calculating the drop size is to assume a distribution of drop sizes which is experimentally observed and then calculate the statistical quantities which describe the distribution dynamically as the parent drop moves in a flow field and generate random numbers to get the child drop size. I would post this question on Fluent's forum or to their customer support to get details of exactly how they get their distribution (Incase you didn't notice Fluent is not open-source)
Atomization and Breakup model xck1986 OpenFOAM 4 May 31, 2014 05:43
Incompressible Turbulence models achinta OpenFOAM 4 May 27, 2010 11:35
Two-fluid models vs mixture models for bubbly flows Hansong Tang Main CFD Forum 6 December 8, 2009 04:21
informaiton about k-omega models krisreddi CFX 2 August 10, 2005 07:53
CFD models Xie Main CFD Forum 0 April 18, 2002 14:48
