Simple CFD question for those in the know
Old   August 2, 2011, 14:15
Arrow Simple CFD question for those in the know
judderod is on a distinguished road
Hi all,
I have a question that hopefully can be easily answered by someone who knows more about fluid dynamics than me.
As I understand, a velocity stack can be used to increase the velocity of fluid that passes through a tube when it is located at the entry of the tube and fluid is flowing towards and through the stack before it enters the tube.
But what about when fluid is flowing the other way?
Imagine a fluid moving along a small tube towards the centre of a face of a box. On the opposite face of the box is the fluid exit point.
How should the tube enter the box to allow fluids passing through it to enter at the greatest possible velocity?
My thoughts on the possibilities are:
a) a simple perpendicular butt joint where the tube is flush with the face of the box
b) the tube passes through the face of the box and protrudes internally by some small distance
c) the tube passes through the face of the box and is terminated with a velocity stack
Finally, if the exit point of the box was adjacent to the entry (rather than opposite), would this affect the answer?
Your thoughts are warmly welcomed
judderod is offline   Reply With Quote
Old   August 2, 2011, 15:19
Martin Hegedus
Martin Hegedus is on a distinguished road
Do you want the fluid to go through at a maximum velocity or mass flow rate?
A flipped velocity stack is a diffuser. To minimize losses you would have a diffuser when entering the box and a velocity stack (contraction section) when exiting the box. This will help maximizing the flow rate. However, a diffuser will not maximize the velocity entering the box.
Martin Hegedus is offline   Reply With Quote
Old   August 2, 2011, 15:40
Yes thanks for correcting me - flow rate is the goal. I'm still getting my head around the terms!
So if I've understood correctly, this is what I should aim for:
Which direction of flow would produce the highest flow rate?
Or is there an even more efficient way like a more gradual tapered inlet/outlet?
Old   August 2, 2011, 16:08
Martin Hegedus
Sort of. But the right and left side should look similar. In the case above, and this is a total guess, the flow going right to left may be more efficient. If the flow were going left to right there may be a stagnation point on the half circle and the flow would have to split, one streamline up, the other down. The up stream line would then eventually hit another stagnation point, which will become a separation point. Of course this is also true if the flow is going the other direction, except the stagnation point on the half circle becomes a separation point. I'm also guessing that the exit would be more sensitive to geometry than the entrance. So effort should be focused there. The overall objective for the entire system is to try minimize the creation of unwanted vortices. You'll also want to miminze the amount of turbulence created since some of it will go out the exit. For example, an ellipsoid "box" may be better than a rectangular box.
Edit: When I mention the stagnation point on the half circle, I mean the top half circle. The top stream line will go up the side of the box wall and the bottom stream line will go out the exit.
Old   August 2, 2011, 16:26
Martin Hegedus
Oh, one more thing. I wrote that the entrance and exit should look similar. Not really true. If you are trying to optimize this, the two will look different. For the entrance to the box, the flow will want to separate somewhere on the nozzle/diffuser. On the exit of the box, the flow will want to separate in the throat.
Old   August 2, 2011, 17:32
Martin Hegedus
Since a picture is worth a thousand words, I've attached a panel solution (Aero Troll + PANAIR) for a stretched donut.
When the flow is entering the donut it sees the minimum pressure at the throat and then a slight increase. This slight increase could cause flow separation and a blockage of the throat. The idea is to create a geometry that insures this does not occur. When the flow exists the donut it sees the minimum pressure at the throat and then an increasing pressure in the diffuser section. This will cause separation at some point. The idea is to minimize the effects of this. There may not be that much you can do about it. However, sometimes it is important to fix the separation point so unsteady flow does not occur.
Old   August 3, 2011, 09:52
Many thanks for your very helpful advice Martin.
Further to this I've since found some interesting data that is referenced in wiki.
Sure enough, velocity stacks do perform differently when the flow is reversed. Assuming 'spitback' gives us a good idea of flow from right to left, I think it's fair to say an elipsed radiused velocity stack (bottom row) will provide the maximum flow rate in both directions.
This study also showed that differences in the radius of a velocity stack resulted in only a 3.5% difference in the measured mass flow rate on intake (top left & bottom left). Outlet readings were not measured, but looking at the right column, is it fair to assume the differences would probably be more significant?
Old   August 3, 2011, 12:39
Martin Hegedus
Hard to say if it is significant. I'm guessing that the spitback results are transitory? Maybe steady state would be different. This is where analysis/CFD and experimentation would come in...
Good Luck.
Old   August 5, 2011, 12:05
Yes. It's the best I've got to go on at the moment so I'll have to press ahead with a prototype.
No prizes for guessing what it is...
Question about J D Andersons CFD Introduction book siw Main CFD Forum 4 July 22, 2008 07:33
Question regarding CFD PhD Mateo Main CFD Forum 4 January 5, 2006 04:52
Question for CFD programmers Renato Main CFD Forum 15 October 17, 2005 07:07
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
