August 2, 2011, 07:45 |
Strouhal Number
David
Hello all. I'm currently designing a method for determining noise in orifice plates. Im dealing with hydrodynamic flow at present and am trying to modify the IEC 534-8-4 standard for noise predictions in control valves as so it can be applied to orifice plates.
Anyone who is familiar with control valves and governing equations will know several coefficients and parameters are often supplied by the manufacturer (eg sizing factors, valve style modifiers and numerical constants). Not having these parameters available for orifice plates I was wondering if anybody is familiar with determining the Strouhal Number for such flow, given know process parameters for an orifice plate. I need the Strouhal number to find the peak frequency of the system. Also anyone who has attempted a similar problem in the past, any overall input would be massivley apreciated. Thanks. |
August 2, 2011, 16:06 |
Rep Power: 15 |
You may find more information if you look into the Von Karman vortex street solutions. This is where the Strouhal number arises.
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 13:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 11:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
