U.F.D. :Finite Differences on Unstructure grids
Old   August 3, 1998, 12:54
Default U.F.D. :Finite Differences on Unstructure grids
STROHM
During my thesis I developped a way to make Finite Differences on Unstructured grid. The problem is that I found very few references on that subject. If anyone has some information on that topic, it would be very helpfull to me. THANKS IN ADVANCE.
Old   August 5, 1998, 00:10
Default Re: U.F.D. :Finite Differences on Unstructure grids
H Dou
Can you describe your Finite Differences on Unstructure grids. I have experience about Finite Volume Method on Unstructured grids. Most used Finite Volume Methods on Unstructured grids are two types: 1. time marching( e.g. Jameson) 2. pressure based method(e.g. Patankar,Baliga)
What is the difference of your method from these?
Old   August 5, 1998, 05:19
STROHM
Contrary to Finite Volume Methods UFD doesn't use control volume nor integration of the equations. Like in structured grid, the starting point is the Taylor series expansions ; but here, the Taylor series are made over the space on points that may not be on line coordinates. Thus, any kind of partial differential equations can be discretized, like Navier-Stokes equations, heat transfert or Maxwell 's equations. Then, UDF are not particularly time marching related or pressure based.
Old   August 5, 1998, 09:57
xiaojian wang
you conducted an interested subject, I didn't know any refernces in this subject, hopefully after you finish your thesis, I can obtain one copy of it.
wang
Old   August 6, 1998, 16:25
Z.J. Wang
You definitely have an interesting academic topic to study on. As you know, there aren't many people (if any) doing finite difference on unstructured grid.
There is, however, one very siminar idea in a paper published by Batina of NASA Ames several years back (92-93) on a gridless method. The method used a cloud of points to form the partial differential, which is idential to your idea in a sense. The paper was published as an AIAA paper. You probably could find it by searching the name of the author.
good luck
ZJ Wang CFD Research Corp.
Finite Difference on unstructured grids ? DoHander Main CFD Forum 9 May 21, 2023 21:58
References for the finite volume method on unstructured grids old newbie Main CFD Forum 1 April 26, 2011 00:53
Finite volume solution methodology for Unstructured grids Dhileep T K Main CFD Forum 1 May 4, 2010 07:38
Multigrid for finite differences Enda Bigarelli Main CFD Forum 4 November 6, 2001 13:04
Finite differences Zdravko Stojanovic Main CFD Forum 8 March 24, 2001 23:31
