MPICH for Windows (Fortran)
Old   April 29, 2005, 10:04
Default MPICH for Windows (Fortran)
jojo
I have installed MPICH for Windows and tried to compile my first program. As I use Fortran, I have included the file mpif.h.
I cannot call the routine MPI_INIT(). The compiler report that this routine is not defined. Effectively, MPI_INIT() does not appear in mpif.h, while its C prototype may be found in mpi.h.
Has the distribution of mpif.h a known bug?
Thanks in advance for your help.
jojo
Old   April 29, 2005, 10:43
Default Re: MPICH for Windows (Fortran)
ag
Sounds like you're not linking to the correct libraries.
Old   May 2, 2005, 10:54
jojo
Thanks a lot for your answer.
In which library file is MPI_INIT? MPI appears very unclear for me. I do not really understand how it is organized.
Thanks,
Best Regards,
jojo
Old   May 2, 2005, 12:31
ag
On my system it looks like libmpi.a. You can use the 'nm' command to search archives. Try 'nm "library name" | grep -i mpi_init ' to look at the archive "library name". If the object is in the archive and defined you should only see a line that begins with 'T' followed by the object name.
Old   May 3, 2005, 10:10
jojo
I have found libmpich.a. Unfortunately, I use Windows XP and cannot read libmpich.a but I assume it is OK as you mention.
This file is in MPICH\SDK.gcc\lib and my (simple) makefile is as follows:
================================================== = # Makefile
toto: toto.o
g77 -I"C:\Program Files\MPICH\SDK.gcc\include" -L"C:\Program Files\MPICH\SDK.gcc\lib" -lmpich -o toto toto.o
toto.o: toto.f
g77 -I"C:\Program Files\MPICH\SDK.gcc\include" -L"C:\Program Files\MPICH\SDK.gcc\lib" -lmpich -c toto.f ================================================== ==
This makefile does not lead to any error excepted the one I mentioned when I try to include MPI routines but I think it is wrong and this is my problem.
Thanks a lot for your help.
jojo
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 06:37
distributed mpich problem Trevor CFX 15 January 9, 2007 18:08
visual fortran Monica Main CFD Forum 1 August 28, 2004 21:45
Intel Fortran (ifort 8) and MPICH Goicox Main CFD Forum 4 April 28, 2004 01:59
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 16:16
