A general question on solving NS equations with an ALE description |
July 22, 2011, 04:26 |
Rep Power: 16 |
Just a general question about the ALE approach. In the ALE approach you have both the mesh velocity and the flow velocity and therefore an extra unknown has been added to the NS equations. Is an extra equation needed to solve the equations now and what would that equation be? Thanks, H |
July 23, 2011, 17:08 |
private
Rep Power: 17 |
The mesh velocities (magnitude and direction) are input to the fluid motion equations. You have to prescribe those velocities. You can specify values appropriate for your problem or
use appropriate physics (boundary motion, acceleration, ???) to specify an equation of motion for the mesh points. |
July 23, 2011, 17:54 |
Rep Power: 16 |
Thanks very much.
I have seen a few relationships and am confused by them a little. What I was thinking about was to use this relationship: dv/dL = constant, where L is the cell length. But I'm not sure maybe I should use: dv/dt = constant, Or dL/dt = v(t=n) - v(t=n+1), Or that the cells are increased or decreased in size by the same amount such that dL/dt = constant i.e. v = constant. I would appreciate you help. Thanks, H |
August 7, 2011, 06:18 |
Initial conditions for an unsteady flow problem in 1D
Rep Power: 16 |
I was going to post a new question and accidentally wrote here. Please ignore this...
September 5, 2011, 18:47 |
unsteady flow - issue with for loop
Rep Power: 16 |
Darcy-Forchheimer law for specifying Porous Zones | Ger_US | OpenFOAM Running, Solving & CFD | 37 | April 10, 2022 03:38 |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 13:52 |
Negative value of k causing simulation to stop | velan | OpenFOAM Running, Solving & CFD | 1 | October 17, 2008 05:36 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
