timestep for time dependent RANS
Old   April 28, 2005, 05:46
Default timestep for time dependent RANS
fab
I wonder if there is a size limit of the smallest time step for unsteady RANS models. I read that the averaging time T should be T>> Tf , where the turbulent fluctuations have the time scale Tf.
Where is the problem setting T=Tf?
Maybe, someone has an explanation.
Regards! fab
Old   April 28, 2005, 08:22
Default Re: timestep for time dependent RANS
Tom
The problem with T=O(Tf) is that in performing the Reynolds averaging you have "averaged out" these time scales. Furthermore in oder to justify retaining the d/dt term in the averaged equations there must be scale separation (i.e. T >> Tf ). In unsteady RANS the unsteadiness should be viewed as a slow modulation of the more rapid turbulent fluctuations.
Old   April 29, 2005, 02:41
fab
thanks! I found for Tf: Tf= max (k/epsilon, alpha sqrt(nu/epsilon)) with alpha=6.
So should the limit for T be: T > 10*Tf ?
Regards! fab
Old   April 29, 2005, 04:18
Halim Choi
Read the following paper, G. Iaccarino,A.Ooi, P. A. Durbin, M. Behnia, "Reynolds averaged simulation of unsteady separated flow", International Journal of Heat and Fluid Flow,Volume 24, 2003, pp.147-156. Then you can get answer for your question.
Old   May 2, 2005, 02:29
fab
thanks! I will try to get a copy.
Greetings! fab
Restart 2-way FSI with different timestep? Lance CFX 10 April 17, 2013 01:37
RANS in integral form siw Main CFD Forum 0 August 17, 2010 04:18
Mapping RANS data onto an LES christian OpenFOAM Running, Solving & CFD 0 April 13, 2007 06:31
Timestep and RANS assumption HS FLUENT 2 November 19, 2005 18:10
Request for truth on VLES/Unsteady RANS Nick Georgiadis Main CFD Forum 16 September 1, 1999 17:43
