CFD related undergraduate project??
Old   July 20, 2011, 11:35
Default CFD related undergraduate project??
Digant
digant26290 is on a distinguished road
I am last year engineering student and would like to do project in cfd..for final year project..does any one have ideas?
digant26290 is offline   Reply With Quote
Old   July 20, 2011, 16:56
cfdnewbie
cfdnewbie is on a distinguished road
please be more specific!
do you want to apply CFD, or develop your own code? What software do you have available? Theoretical background, practical background, time frame, etc pp
Cheers,
cfdnewbie
cfdnewbie is offline   Reply With Quote
Old   July 21, 2011, 05:36
A.D.E is on a distinguished road
Do you have a specific area of interest?? CFD can be applied in a variety of problems from Biomedical to Aerospace! I think it is important for you to select a field first! Preferably something that you are good at. Once you do that it will be easier to find a specific area of research.
Sincerely,
A.D.E
A.D.E is offline   Reply With Quote
Old   July 21, 2011, 08:04
Digant
Fluid flow is and area of interest....
Can u suggest some topic related
Old   July 21, 2011, 18:28
cfdnewbie
application or development??
Old   July 22, 2011, 01:08
Digant
application would be better..
as we have got 12 months...only..
Old   July 22, 2011, 08:20
Thumbs up We can do it together SIMPLEC
kid
cfdkid
kid is on a distinguished road
Hello friend,
If you like my offer we can do your project together .
kid is offline   Reply With Quote
Old   July 24, 2011, 14:26
Martin Hegedus
Martin Hegedus is on a distinguished road
This might sound boring, and I'm not sure if something doesn't already exist out there. I haven't seen anything concerning this. And I think it is needed.
Take serveral NACA 00xx airfoils (for example, 0004, 0006, 0010, 0012, ... 0030), or another airfoil of your choice, and run them incompressible (or low Mach number, 0.1) over a range of Reynolds numbers, 50k, 100k, 500k, 1mil, 5mil, 10mil. with different turbulence models, SA, SST, and a transition model of some sort. Go from 0 angle of attack to something well past stall, lets say 24 degrees angle of attack. Where possible, compare with data. Post the results on a web page. Make it interactive if possible by allowing the viewer to select CFD results and wt data to compare to. You could also create an iPad app out of it.
This could possibly become a reference tool for others. A sort of Abbot and von Doenhoff.
This is a lot of work and could take a lot of CPU time.
Martin Hegedus is offline   Reply With Quote
Old   July 24, 2011, 17:26
Andrew Coughtrie
Andrew.Coughtrie is on a distinguished road
What is your degree in (Aero, Mechanical, Biomedical, Civil?), that might give people a better idea of what areas to suggest, saying you're interested in fluid flow on a CFD forum doesn't really help.
Knowing whether you have access to any commercial software (CFX, Fluent, Adina, LSDyna, Star-CD) would also help, if not then you might possibly be able to use something like OpenFoam as its open source and probably a good place to start rather than trying to build your own code from scratch.
So any more info would help.
Andy
Andrew.Coughtrie is offline   Reply With Quote
Old   July 25, 2011, 15:36
gegu is on a distinguished road
For a research project, you might want to try doing something related to OpenFOAM using GPUs. Here is a link that may help give you some ideas : http://www.nvidia.com/object/computa..._dynamics.html
gegu is offline   Reply With Quote
Final Year Project - CFD on Drag coefficients jamesho123 Main CFD Forum 1 September 15, 2009 22:50
Under Graduate project in CFD Monali Gupta FLUENT 1 February 13, 2008 17:15
undergraduate level thesis in cfd fazle rabbi ahad Main CFD Forum 5 December 5, 2006 11:38
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 09:10
Undergraduate thesis project Shadhanan Manickavasagar FLUENT 5 August 19, 2000 23:59
