May 25, 2020, 15:23 |
#41 |
Gang Wang
Rep Power: 7 |
BTW, I know it might be impossible because the total grid number I need is approximately Re^(9/4). But I want to use a finer mesh to try LES simulation. But I cannot find a criterion about mesh size used in LES, maybe delta x and delta z? But I think if I could draw a mesh which could be close to kolmogrove scale, it would be great.
May 25, 2020, 15:25 |
#42 | |
May 25, 2020, 15:29 |
#43 | |
Gang Wang
Rep Power: 7 |
Best, Gang |
May 25, 2020, 15:34 |
#44 | |
Filippo Maria Denaro
Rep Power: 73 |
As Paolo wrote, you can assume that the integral length scale is of the order of the diameter. Your domain must be enough long and large to allow a physical correlation of the structures at such length. I suppose you assume periodic condition in spanwise direction and the extension must be enough wide. In case of a DNS you need of a grid that must be refined in the BL in such a way that at least 3-4 nodes are at y+<1 (y+ is nothing but the local Re number measured in direction normal to the wall). This constraint is valid also for a resolved LES. In the latter case you can use a larger grid size in spanwise direction. |
May 25, 2020, 15:38 |
#45 | |
Gang Wang
Rep Power: 7 |
Best, Gang |
May 25, 2020, 15:43 |
#46 | |
Rep Power: 73 |
while close to a wall you need to resolve the BL profile, that means you need more nodes in the viscous sublayer, the spanwise direction can be discretized in LES using dz+ =20-30. There are references in the textbook of Sagaut as well as papers published. For example have a look here https://www.researchgate.net/publica...ates_revisited |
Mesh size for les ? | shahzeb irfan | Main CFD Forum | 2 | May 27, 2011 01:39 |
Mesh size for les ? | shahzeb irfan | FLUENT | 0 | May 19, 2011 00:26 |
L/Δ factor for LES mesh | faisal_durr | ANSYS Meshing & Geometry | 0 | February 17, 2011 08:56 |
LES on a scaled geomentry (Mesh and Large scales) | comb | Main CFD Forum | 0 | February 8, 2011 06:21 |
LES grid mesh | L3munoz | Main CFD Forum | 0 | April 7, 2010 05:05 |
