May 13, 2015, 10:23 |
#21 | |
Filippo Maria Denaro
Rep Power: 73 |
Hello, I strongly suggest to read some topics in this forume about filtering,LES, DNS, many if not all answers are here... good search |
May 14, 2015, 12:32 |
#22 |
Thanks professor, I have already done. However, the more I read the less I understand...
May 14, 2015, 12:34 |
#23 |
Rep Power: 73 |
May 14, 2015, 12:41 |
#24 |
May 14, 2015, 12:52 |
#25 |
Rep Power: 73 |
October 5, 2016, 17:09 |
#26 |
Mirage
Rep Power: 14 |
I went through all the replies and other threads and papers and I am not seeing any clear answer about the requirement of LES grid.
Generally we can say that the grid resolution is depending on the physical problem and it is for me clear that the filtering and accuracy of the results is depending on the the smallest cell, used as parameter to specify the range of the modeled energy spectrum. However I am not finding any paper, book, reference, which gives a clear and simple explanation or correlation about the mesh requirement for LES ! I was wondering, if someone could give an answer to this question Thanks |
October 5, 2016, 17:13 |
#27 | |
Rep Power: 73 |
what is not clear? the mesh introduces a projective filter at a frequency corresponding to the Nyquist cut-off. In LES one must ensure that this frequency lies in the intertial range of the energy cascade |
October 5, 2016, 18:47 |
#28 |
Professor Denaro has answered your question. My opinion is that the literature shows more information about the mesh requirement for DNS than LES. In LES your need to make sure that the cut-off frequency imposed by the mesh lies in the inertial su range. Pope's book is a good reference.
October 5, 2016, 20:16 |
#29 | |
Mirage
Rep Power: 14 |
Let me try to specify what I do not understand: I was wondering how to verify that my grid is appropriate for a LES Simulation. Many references mentioned that y⁺ should be small than 1 , if the wall modeling is not used which I can totally understand. Do you know if other rules for Δx⁺and Δz⁺ exist? Could you please share with us, which steps are you taking to be sure that the mesh is good enough for a LES? Which grid parameters should I take in account when i generate my mesh and how can verify after the solving that my results are acceptable in the framework of LES results. Thank you so much ! |
October 6, 2016, 03:12 |
#30 |
Rep Power: 73 |
you should consider the flow problem.... if you are working in fully confined flows, no matter of the directions, x+,y+ and z+ are measured from the walls and you have to work with a DNS-like grid near the walls for a resolved BL. That means 3-4 nodes at least within x+,y+,z+=O(1).
If your problem has some directions of homogeneity the LES grid has a typical dimension of h+ = 20-30 |
October 6, 2016, 04:21 |
#31 |
Rep Power: 73 |
October 6, 2016, 21:18 |
#32 |
Mirage
Rep Power: 14 |
Thank you very much !
July 15, 2017, 13:06 |
#33 | |
dilaw meda
Rep Power: 9 |
August 28, 2019, 09:26 |
#34 |
Saiprahallad,Sunku
Rep Power: 7 |
Hi Sridhar,
Can you send me your email address... |
May 25, 2020, 14:29 |
#35 | |
Gang Wang
Rep Power: 7 |
I know it's an old thread but I'm still quite interested in this topic about mesh size, Kolmogrove scale and DNS. Like Mr. D. Reynolds said, epsilon is associated with the eta. But through the epsilon expression Mr. D. Reynolds post, epsilon = u'^3 / L. I think this epsilon is a resolved part of epsilon, right? It's closely related to velocity flunctuation, but what about L? Is L the computational length? Can anyone give me some suggestions about how to get epilson in DNS or LES? I don't think it's a modelled one. Best, Gang Wang |
May 25, 2020, 14:37 |
#36 | |
Gang Wang
Rep Power: 7 |
https://physics.stackexchange.com/qu...v-length-scale "From the quotes poem, you can anticipate that everything that is dissipated at the smallest scales, has to be present at larger scale first. Therefor, as a very crude estimate, for a system of length 𝐿 and size 𝑈 (and dimensional grounds, on this scale viscosity does not play a role!)," Which one is right? Best, Gang |
May 25, 2020, 14:47 |
#37 |
Rep Power: 73 |
The viscosity of the fluid plays a fundamental role in defining the Kolmogorov lenght scale.
Just as a rapid estimation, at this scale corresponds a Re number of O(1). |
May 25, 2020, 14:51 |
#38 | |
Gang Wang
Rep Power: 7 |
Yes, I think we could also estimate is roughly using Re^(3/4)* (The maximum eddy scale). But I was also wondering what's the maximum eddy scale in my simulation? If I used a box computational domain, is this the largest side length of my domain? Best, Gang |
May 25, 2020, 15:11 |
#39 | |
Rep Power: 73 |
What you want is the integral length scale L that depends on the specific flow problem. That means you should ensure that your domain has a dimension such to describe properly the structure of dimension L. |
May 25, 2020, 15:18 |
#40 | |
Gang Wang
Rep Power: 7 |
My flow problem is quite esay to understand: 3D simulation of Flow around the circular cylinder at Re=3900, just want to carry out a benchmark test to validate my DNS code is feasible. I think the largest integral length scale is not the length of my domain, maybe width or height? Any suggestions? Best, Gang |
Mesh size for les ? | shahzeb irfan | Main CFD Forum | 2 | May 27, 2011 01:39 |
Mesh size for les ? | shahzeb irfan | FLUENT | 0 | May 19, 2011 00:26 |
L/Δ factor for LES mesh | faisal_durr | ANSYS Meshing & Geometry | 0 | February 17, 2011 08:56 |
LES on a scaled geomentry (Mesh and Large scales) | comb | Main CFD Forum | 0 | February 8, 2011 06:21 |
LES grid mesh | L3munoz | Main CFD Forum | 0 | April 7, 2010 05:05 |
