April 6, 2005, 06:39 |
missing faces....
hi,everyone
i have a problem in making periodic mesh with ICEM. I use icem import the pump model *.igs.if I mesh it without periodic,everything is ok,but,if i mesh it with periodic,hub and shroud will lose some faces, that is mean i can see the mesh ,but i can't see some of hub faces and shroud faces(wall).Anyone can help me?thank you very much! regards! iceraining |
April 6, 2005, 07:41 |
Re: missing faces....
Check it again using "Premesh", possiblility is that you have not projected the faces to the surface. Use "Face projection" to check it
April 6, 2005, 07:47 |
thank you very much,i will do as you tell me another question,why everything is ok when i mesh it without periodic?can you explain it to me? reguards!
iceraining |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 11:37 |
