Using sliding mesh for unsteady turbomachinery problem |
June 17, 2011, 08:43 |
Rep Power: 15 |
Hi all,
I am currently modeling a turbine using periodic functions so my domain is one stator/rotor/stator arrangement. Having used mixing planes for steady calculations i now am running unsteady calculations and from what i have researched i need to apply a mixing plane for this. My problem is the periodicity of each zone must be the same, however i have 26 stators (on each set upstream and downstream of rotor) and 30 rotor blades so it is not. I do not have the computational power to model the full wheel so need to scale the stator zones somehow. Do i just scale dimensions in the radial plane and leave height as is or how do i do it? Do i need to scale inputs or results from the zone? Or is there an easier way? Previously i have modeled unsteady flow on this problem using mixing plane but it only works uni-directionally and not bi-directionally (as is the nature of this flow). Thanks in advance for any help. |
June 20, 2011, 11:00 |
A. S.
Rep Power: 17 |
May be I can help; also you could be help for me, drop a mail shukla_apoorv1975@yahoo.co.uk or alternately we can have a chat on gtalk
June 23, 2011, 07:53 |
Rep Power: 15 |
Anyone else have any suggestions?
July 8, 2011, 15:29 |
Rep Power: 15 |
If you have the capability for a half rotor simulation you can do a 15 rotors/13 stators passage simulation. You could also add a stator blade and do a third passage simulation of 10 rotors/9 stators. This shouldn't increase the stator section solidity by very much and is a very common strategy for running turbomachinery applications. In my experience, the mass flow through the machine is affected very little by adding an additional stator blade to find a common denominator in blade counts. Typically on the order of 1% or so.
CFD engineering resource |
sliding mesh, turbomachinery, unsteady flow |
Sliding mesh model problem | Usman | FLUENT | 9 | January 30, 2015 06:37 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Sliding mesh problem | Michel | FLUENT | 1 | January 15, 2009 11:18 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
