Question regarding non-uniform FVM staggered grid
Old   June 17, 2011, 06:39
Default Question regarding non-uniform FVM staggered grid
TWB
quarkz is on a distinguished road
I have a question regarding non-uniform FVM staggered Cartesian grid.
When the grid is non-uniform, I believe there are 2 ways to discretize the volume of the u/v grid, assuming the p grid is created.
1. The east/west faces of the u grid intersects the cell center of p. In that case, the distance of the east/west faces from the cell center of u will be different. the volume of u and p cells are different.
2. The west face of the u grid intersects the cell center of p but the east face does not. The volume of the u cell and p cell are equal, except shifted. In that case, the distance of the east/west faces from the cell center of u will be different.
Are these 2 discretizations sound? Is there any preferences of one over another?
Thanks
quarkz is offline   Reply With Quote
Old   June 17, 2011, 11:05
otd
private
otd is on a distinguished road
I think there's a real advantage in having the cell faces coincide with the p locations (cell centers). Try a simple one-d steady state heat conduction problem as an easy-to-derive example. With fixed temperatures at each end, this problem has a simple analytic solution. Expand your two differencing choices in Taylor series and example the lower-order terms that you truncate. One of the two choices will have a leading truncated term that grows as 1 over dt for a non-uniform mesh!
otd is offline   Reply With Quote
Old   June 18, 2011, 18:18
TWB
thanks for your explanation.
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 09:07
buoyantSimpleRadiationFoam msarkar OpenFOAM 0 February 15, 2010 07:22
Problems with Turbulence Modeling ezsoal OpenFOAM Running, Solving & CFD 4 November 26, 2009 16:12
RasInterFoam STRANGE RESULTS AT BOUNDARY kumar2 OpenFOAM Running, Solving & CFD 8 March 24, 2008 19:38
Incompressible flow solver (staggered grid) J. Ehrhard Main CFD Forum 1 October 8, 1998 20:47
