Method for solving the adjoint equations
Old   June 12, 2011, 22:31
Default Method for solving the adjoint equations
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
I have run several cases and found it difficult to obtain a converged
solution of the adjoint N-S equations. I think it is related to the adjoint
transpose convection term. I use the SIMPLE algorithm to couple the
adjoint velocity and pressure.
What should I do to improve convergence of the adjoint equations?
Any information, however small, would be appreciated.
Best regards,
fumiya
fumiya is offline   Reply With Quote
Old   June 13, 2011, 01:18
Felipe Hernandez
Petrov is on a distinguished road
First, check that you should get a solution that converges. For high Re, (even about 40 in some cases), you would get a time-dependent solution. To check that it works for low Re, increase the viscosity, decrease the velocity, etc. If this doesn't work, there is a problem.
I don't know much about the SIMPLE algorithm, but if it involves solving a system of equations, try using a pre-conditioner. Without a pre-conditioner, I was not able to get a good result quickly. I implemented the gauss-siedel conditioner and it works like a charm. (Though maybe I should use SSOR!)
Good luck!
Petrov is offline   Reply With Quote
Adjoint solver for flow problems jelmer OpenFOAM Running, Solving & CFD 11 March 12, 2017 07:52
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
CFD governing equations m.gos Main CFD Forum 0 April 30, 2011 15:21
A question about discrete adjoint method Thomas Main CFD Forum 3 August 9, 2006 13:37
What is Density-Based method? C-H Kuo Main CFD Forum 4 November 18, 1998 17:11
