Rendering your CFD results - general discussion |
August 12, 2013, 11:43 |
#41 |
cfdnewbie
Rep Power: 20 |
Hello Markus,
what worked for me was to change the version of blender (from 2.63a back to 2.62 I think), but I couldn't find a "true" solution to this problem. All the best! |
August 13, 2013, 10:30 |
#42 |
Markus Rehm
Rep Power: 17 |
so you still use an old version? Can you track the error back? https://projects.blender.org/scm/vie...s&pathrev=4362 or git https://github.com/ldo/blender-addon.../import_x3d.py I just downloaded the latest release 2.68a and have the same problem. I will try to send a bug report or consult the blender forum. Markus |
August 26, 2013, 17:39 |
#43 |
cfdnewbie
Rep Power: 20 |
Hello Markus,
yes, I'm still using 2.63a. Just tried importing an x3d file with 2.63a and the current 2.68. The 63a works fine (no black), the 68 gives the ugly black stuff. Did you have any luck with the blender community on this? Here's sadly another problem (at least with 2.63): As soon as the x3d-file exceed a size limit of about 800 MB, the import won't work anymore (for a sinle file). If I split the 800 Mb file into two 400mb x3d files, it works.... always a lot do work around with free software Cheers and good luck |
December 12, 2013, 23:13 |
#44 | |
Thanks! -Nuc Last edited by Nucleophobe; December 14, 2013 at 14:17. |
December 14, 2013, 05:27 |
#45 |
Just wanted to add my contribution to the discussion. Many companies are moving towards that direction for marketing reasons.
Here's a cool video: http://www.youtube.com/watch?v=nWUKg...cdFCHA&index=1 |
December 14, 2013, 14:10 |
#46 | |
I guess I could put a plug in here for a few videos I worked on. In some of our lab's biological fluid simulations, where the time history of the particles is important (blood flow & olfaction), I thought it would be interesting to animate the camera to follow a streamline: http://www.youtube.com/watch?v=0cak1mFTTJo http://www.youtube.com/watch?v=4RNaIqnaxWo I think that good visualization is not only useful for marketing, but also, if done correctly, for helping your audience understand the fluid mechanics. By the way, have you guys seen the work from Oak Ridge: http://www.blendernation.com/2011/11...supercomputer/ or TotalSim?: http://www.youtube.com/watch?v=TXMPE5mtXcw Let's keep this discussion going - it's fun to see the latest and greatest in visualization! Ciao! -Nuc Last edited by Nucleophobe; December 14, 2013 at 14:34. Reason: Fixed link for Oak Ridge simulations |
June 20, 2014, 07:42 |
#47 |
I recently made a small presentation to get a group of local openFoam users started with rendering CFD result using Blender. It comes with result files (in VTK format) that can be used in ParaView.
Presentation: http://www.slideshare.net/JuliendeCh...-using-blender Files: https://s3.amazonaws.com/cfdresultsp...ng+Blender.zip Feedback welcome.
--- Julien de Charentenay |
May 8, 2015, 11:12 |
#48 |
Rep Power: 18 |
This is fantastic! Can anyone post the python code for to an accessible location? Blender forums says I'm not allowed to read the post unfortunately...
Cheers |
December 21, 2015, 11:13 |
#49 | |
Rep Power: 12 |
Hi Julien,
thank you very much for these interesting slides. Unfortunately I can't access the zipped files any more. The link seems to be outdated. Would you, or anyone else, mind to post them once again? Thanks in advance, best regards, Kate Quote:
December 21, 2015, 13:39 |
#50 | |
Andre Z
Rep Power: 17 |
My favorite animation of the year is this one: https://www.youtube.com/watch?v=T7A1cN5_DrM |
July 4, 2016, 18:35 |
Hi Ralf
#51 | |
alberto
Rep Power: 10 |
the link looks doesnt work anymore, can you tellme if i can find anywhere?
July 5, 2016, 15:25 |
#52 |
This link should work:
http://www.personal.psu.edu/dab143/O...gun_slides.pdf |
September 18, 2017, 17:14 |
#53 |
badoumba
Rep Power: 13 |
Hi rendermen,
Using Blender 2.76 currently. Have someone find so far a way to get the x3d vertices color showing up in Cycles ? (my model is too complex for a clean texture baking) Thanks! |
February 11, 2018, 10:30 |
#54 |
Rep Power: 11 |
Blender 2.79 works OK
January 15, 2019, 12:53 |
CFD -> Paraview -> blender framework
#55 |
hello guys,
in case you are interested in rendering your CFD results in blender, we have a toolchain and tutorial available here, You can also download the sample files from github The toolchain contains some python scripts that automate most of the work needed. The only prerequisites are that you have paraview and blender available, which are both open source and that you can import your solution files into paraview. Good luck and let us know if you encounter any issues. adb |
January 17, 2019, 14:06 |
#56 | |
Yes, this can be done via the node editor. You have to enable "use nodes" and add an attribute node with the Name "Col". See also the tutorial link in my other post for details on how to do this. It took me also some time to figure it out! |
Matching CFD results and wind tunnel testing | huskerwong | Main CFD Forum | 0 | July 16, 2009 15:24 |
CFD vs Experimetal Results for Aerofoil | aceofharts414 | Main CFD Forum | 0 | April 22, 2009 08:14 |
please help me for general description of CFD | Jiyeon | Main CFD Forum | 3 | April 7, 2009 17:20 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
CFD - Trends and Perspectives | Jonas Larsson | Main CFD Forum | 16 | August 7, 1998 17:27 |
