Steady state vs. mean transient analysis of flow behind a circular cylinder
Old   June 8, 2011, 13:26
Default Steady state vs. mean transient analysis of flow behind a circular cylinder
Heini Rasmussen
Heini is on a distinguished road
Hi
I'm looking at the current reduction behind a circular cylinder in a steady flow, at Re = 2100. I have solved it with a steady state solver and k-eps turbulence model, using Fluent. But is this a good enough approach, if one needs a detailed "image" of the flow reduction behind the cylinder? My guess is that a statistical mean velocity of a transient analysis, would show a broder flow reduction path close to the cylinder, than what would be predicted from the steady state solution, due to the detail of the vortex street. Any comments about this proposal, or does anby one know of articles regarding this subject?
Regards,
Heini
Heini is offline   Reply With Quote
Old   June 9, 2011, 07:47
Vesselin Krastev
vkrastev is on a distinguished road
I have some experience at higher Reynolds numbers (form 1e05 to 3.6e06) in simulating the two-dimensional flow around circular cylinders. I can tell you that accounting for the vortex shedding makes a significant difference in terms, for instance, of the predicted pressure drag coefficient: applying the RNG k-epsilon turbulence model, my time-averaged URANS results were far more accurate than the steady-state RANS results.
Best Regards
V.
vkrastev is offline   Reply With Quote
cylinder, flow reduction, steady, unsteady
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Steady state flow over cylinder vmlxb6 CFX 4 February 16, 2011 16:04
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Flow around a sphere and a circular cylinder Francis Main CFD Forum 0 September 29, 2008 06:16
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 15:37
