please help me about finding local Nusselt No. for natural convection
Old   June 3, 2011, 02:13
Default please help me about finding local Nusselt No. for natural convection
vy
chaiworw is on a distinguished road
I'm doing research about Free convection in enclosed rectangular cavity. There are 2 vertically isothermal walls on 29 - 31 degree c. I dont know how to find local Nusselt number because the temperature on the wall is constant. For the free stream temperature, which part I should pick it up for calculating delta-Temp? I've found some literature, it's shown that I have to use plane of 0.125Cavity from hot wall for calculating Nu at hot wall. And also use plane of 0.125Cavity from cold wall for calculating Nu at cold wall. However,it's just 1 paper I've found so I dare not use it.
please help me find out the answer T T
Thank you so much in advance
Vy
chaiworw is offline   Reply With Quote
Old   June 13, 2011, 05:48
Male
confret2 is on a distinguished road
Are you modelling flow in a differentially heated cavity? Can you extract data at a cross section adjacent to the wall and use the fluid temperature at the extremity of the boundary layer profile?
confret2 is offline   Reply With Quote
Old   June 15, 2011, 14:45
Default Finding Nusselt number
krishna
krishoc is on a distinguished road
nusselt number can be found at cold and hot walls by knowing flux at fluid-structure interface. the detla T value used to be temperature difference b/w hot an d cold wall. refer velusamy et al
krishoc is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
