Wall HTC Impinging Jet
Old   June 2, 2011, 07:52
Default Wall HTC Impinging Jet
Shashank
azurespirit is on a distinguished road
I am running 2-d simulations for jet impingement heat transfer. One of the parameters that I am varying is the jet temperature at the inlet, while maintaining the wall temperature as constant.
In the first case, the inlet temperature is 350k and in the second case it is 450k. For both these cases, the wall temperature is maintained at 300k.
The problem I am encountering is that, when I plot a line on the wall in the results file and extract the values for wall HTC, i am getting the exact same HTC values for both the above mentioned cases. Since I am varying only one parameter in the inlet boundary condition and maintaining all other parameters constant, I would expect to see a difference in HTC values for both the cases, but this isn't happening.
PLease could anyone suggest possible solutions to this problem?
azurespirit is offline   Reply With Quote
htc, inlet boundary condition, jet impingement, wall htc
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 07:23
Wall heat transfer coefficient (HTC) problem Mohamed khamis CFX 1 January 16, 2010 00:12
Impinging Jet Modeling Problem Anindya FLUENT 1 August 11, 2001 04:16
IMPINGING JET PROBLEM Chuck Leakeas Main CFD Forum 4 January 29, 1999 18:43
