convective bc
Old   March 24, 2005, 09:35
Default convective bc
star
I am trying to implement a convective BC for vortex shedding problem.I use a SIMPLEC algorithm.
The convective BC for u,v is: du/dt+Uc*du/dn=0 dv/dt+Uc*dv/dn=0
Then I made the correction for u based on continuity.
Q1: How to choose Uc? Q2: Shoud I use zero gradient BC for pressure correction on the convective BC or fixed the pressure correction to zero? Q3: I tried several combinations of velocity and pressure correction on the convective BC, all failed. It seems that the convective BC is not numericallly stable. However, it works well for steady case such as 2D channel flow.
If you have some experience on it, please make comments and suggestions. Thanks a lot.
solver radiative and convective heat fluxes in CFD-Post user CFX 3 August 3, 2010 09:21
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Convective schemes for vector fields edoardo OpenFOAM Running, Solving & CFD 6 February 16, 2009 12:05
UDF convective heat transfer correlations sarah FLUENT 0 March 29, 2007 10:52
MI & Higher-Order Convective Scheme. Ana Main CFD Forum 0 September 22, 2003 06:01
