is sharp trailing edge a stagnation point?
Old   May 31, 2011, 17:35
Default is sharp trailing edge a stagnation point?
Shenren Xu
Shenren_CN is on a distinguished road
For example, a NACA0012 airfoil with sharp trailing edge of finite angle (not a cusp). If incoming flow is subsonic (isentropic), can the trailing edge be assumed to be a stagnation point?
If I use a node-based, instead of cell-centered, finite volume Euler solver, how to impose weak boundary condition then?
Thanks.
Shenren_CN is offline   Reply With Quote
[ICEM] Hole near sharp trailing edge of airplane/wing geometry jlichtwa ANSYS Meshing & Geometry 2 September 21, 2010 16:19
Structured mesh of a 3d sharp trailing edge Gilles Main CFD Forum 2 May 23, 2008 14:23
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 02:07
