turbulence model for ribbed channel heat transfer
Old   May 31, 2011, 10:47
Smile turbulence model for ribbed channel heat transfer
Kan Rui
keryfluid is on a distinguished road
hello everyone,
Recently I've been working on ribbed channel flow,and heat transfer is of great importance in this problem. I found that heat transfer coefficient distribution calculated by the k-e model (with enhanced wall treatment) are not quite satisfying compared to the experimental results. I wonder if there's some logic to guide me to choose a proper turbulence model, or I can only try them one by one?
Your remark are highly appreciated!
keryfluid is offline   Reply With Quote
Old   June 1, 2011, 02:40
Raashid Baig
cfd_newbie is on a distinguished road
Originally Posted by keryfluid View Post
hello everyone,
hi,
Ribbed channel flow is a very new area to me can you give more details like the Reynolds number involved, details of operating conditions geometry etc. ?
Raashid
cfd_newbie is offline   Reply With Quote
Old   June 1, 2011, 22:34
Kan Rui
Originally Posted by cfd_newbie View Post
hi,
Raashid
It's a serpentine channel used for internal cooling of gas turbine blade. Reynolds number depend on the hydraulic diameter is around 50,000, rib height is approximately 0.1 Dh, rib pitch is 10 Dh. The channel is square with an aspect ratio from 1/4~4 and it may have a 90-degree or 180-degree turning section. Rotational effects is not considered yet.
Old   June 2, 2011, 01:16
Raashid Baig
Did you try the SST turbulence model, this is generally the safest bet and nice starting point. What Y+ are you using right now ? What is the mach number involved ?
Raashid
Old   June 2, 2011, 10:53
Kan Rui
Raashid
Mach number is near 0.03 so I think it's a incompressible problem. Y+ at most part of the wall is around 3, except for some point on top of the rib ,where yplus can be 10.
Old   June 3, 2011, 02:02
Raashid Baig
I think since it's an internal flow than you can increase your mesh count (I hope you have sufficient hardware resources) so that nowhere the Y+ is more than 2. Once you have new finer mesh you can "solve to wall" instead of going for wall functions.
Old   June 3, 2011, 07:36
azt
allan thomson
azt is on a distinguished road
hi
you probably need to go to a low re turbulence model with Y+ around 1, k-w-sst is a good model.
Experience would suggest that the metal temperature is probably being predicted too high. I found this when I did cht analysis on turbine blades. Changing to a low Re model will reduce the metal temperature by around 10 K.
Only problem is you'll need a lot of cells 20 -25 prism layers in the boundary layer
allan
azt is offline   Reply With Quote
Old   June 3, 2011, 07:39
Raashid Baig
Originally Posted by azt View Post
hi
allan
In addition to what Allan has said, if there is a significant laminar to turbulence transition than you should use LMT transition prediction turbulence prediction model.
heat transfer w/o turbulence Andrev OpenFOAM 2 May 12, 2011 14:20
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 22:25
how to model heat transfer for the coupled wall jing113cn FLUENT 0 June 22, 2009 04:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
conjugate heat transfer in circular channel src FLUENT 1 August 6, 2004 08:13
