Problem using EDM for combustion
Old   May 30, 2011, 06:40
Default Problem using EDM for combustion
Nakul
nakul is on a distinguished road
I am trying to simulate combustion in a cylindrical pipe using Eddy Dissipation Model. At the inlet and outlet of the pipe I have made "far-field" domains as the flow around the inlet and outlet is also important.
The boundaries of "far-field" are assigned with ambient pressure and temperature and zero velocity.
In this setup, I am not being able to initiate combustion. I have solved the flow-field (cold flow analysis) but when I switch ON the reaction, no product formation occurs.
I am simulating a completely unsteady problem. I think there is some problem with EDM setup as I got acceptable flow-field from cold flow simulation.
Please Help.
Nakul
nakul is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 11:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
convergence problem Trushar Phoenics 5 August 28, 2002 00:40
