PISO Algorithm
Old   March 15, 2005, 09:38
Default PISO Algorithm
Benedikt Flurl
I have two questions about PISO algorithm: 1. Is underrelaxation for the secons Pressure Correction in PISO never necesseray? 2. Have I also to correct the massfluxes with a expression of the second corrections? (I think, mass conservation should already be fullfilled after the first correction?!)
Thank you for your Help!!
Old   March 15, 2005, 09:51
Default Re: PISO Algorithm
Hrvoje Jasak
1) Provided you solve for the pressure properly, no (beware of non-orthogonal correctors)
2) Yes, you should correct the mass fluxes after every pressure solution - the fluxes are conservative after the first corrector as well but are no longer consistent with the velocity field (which is kind of important)
Enjoy,
Hrv
PISO algorithm for particular NS equation (special convection term) Cyp OpenFOAM Programming & Development 8 June 12, 2012 10:36
piso algorithm in phaseChange phonomena nimasam OpenFOAM 0 November 18, 2010 09:58
Is it possible to use PISO algorithm for steady case Gearb0x OpenFOAM Running, Solving & CFD 9 July 15, 2010 01:49
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 07:54
Piso algorithm Rooz Main CFD Forum 0 October 6, 2003 10:07
