Convection heat transfer & rugosity
Old   May 19, 2011, 04:26
Default Convection heat transfer & rugosity
Koranten is on a distinguished road
I would like to know if rugosity can have a significant impact on the value of the heat transfer convection coefficient ? My system is a long pipe in which I have free convection (Ra > 10^9 and Re > 12 000).
I am assuming a zero rugosity and I think this has no impact, what do you think?
Answers with references would be good!
Best regards,
Koranten.
Koranten is offline   Reply With Quote
Old   May 25, 2011, 00:15
oky
Oky Andytya
oky is on a distinguished road
Hi everyone,
I need help, how to get the value of convection coefficient [h] from Fluent directly?
Thank you.
Regrads,
Oky
oky is offline   Reply With Quote
Old   May 25, 2011, 03:52
You're not helping, but I can help you.
You just have to look a the definition of h, which is :
heat flux = h * DT (W/mē)
So :
h = heat flux / DT
With :
heat flux = area weighted average of surface heat flux
(be careful if you have radiation, you should not take it into account, by doing 'total surface heat flux - radiation heat flux')
DT = T_wall - T_infinite
T_wall = area weighted average of Wall Temperature
T_inf = it is up to you! You should choose what is your reference temperature!
Old   May 25, 2011, 09:54
Andrew
mettler is on a distinguished road
are you treating the rugosity as a change in the area or something like a friction factor for the pipe?..either way, I guess it could impact the convective coefficient if the value is large enough
mettler is offline   Reply With Quote
Old   May 25, 2011, 11:06
I am using FLUENT. The rugosity is set to zero and I'm not sure this could have a real impact, and I cannot do any tests for the moment.
Old   May 25, 2011, 11:12
Andrew
my very limited experience with rugosity leans me to not thinking it would apply to pipe flow, but I could be wrong. I would leave it at zero. Or, you could step it up and see what happens to your results.
model forced convection heat transfer on a heat sink farzad FLUENT 0 September 9, 2010 15:48
Heat transfer, convection, radiation, conduction Sandra H. OpenFOAM 1 March 3, 2010 09:02
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
