Reference Area for Calculating Lift and Drag Coefficient of 3D wing
Old   May 18, 2011, 23:39
Default Reference Area for Calculating Lift and Drag Coefficient of 3D wing
Mahbub Islam
mahbub03 is on a distinguished road
Hi Everyone,
I am having a confusion on calculating reference area for 3D wing. As I know, for the Lift coefficient the reference area is SPAN*CHORD of the wing. But for calculating Cd should that also be SPAN*CHORD? or the frontal area perpendicular to the flow direction?
Thank you for your time. It would be a great help if anybody gives this info.
mahbub03 is offline   Reply With Quote
Old   May 19, 2011, 01:03
Praveen. C
praveen is on a distinguished road
It has to be some area. Which one to use will depend on the data you are going to compare it with. Which area was used to define that data ? If you have nothing to compare, you can use span*chord. If its not a straight wing, use the planform area. Its same for both cl and cd.
praveen is offline   Reply With Quote
Old   May 19, 2011, 01:10
Mahbub Islam
Praveen
Thank you so much. Now I have got the point.
Old   May 19, 2011, 01:21
Raashid Baig
cfd_newbie is on a distinguished road
Originally Posted by mahbub03 View Post
Hi Everyone,
It's SPAN*CHORD for Cd too.
cfd_newbie is offline   Reply With Quote
area
lift & drag coefficient on airfoil n. natik FLUENT 8 March 31, 2015 20:02
Coefficient DRAG and LIFT - Cylinder 3D Jwolf CFX 11 February 4, 2010 06:08
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Lift and Drag on airplane wing Arj CFX 4 October 6, 2006 05:05
drag and lift coefficient Noé Siemens 5 July 13, 2004 11:21
