Validation of Pitch moment for subsonic Delta wing
Old   March 9, 2005, 16:13
Default Validation of Pitch moment for subsonic Delta wing
Riaan
Hi everyone,
I am currently studying the Pitching moment of a 70deg delta wing at low alpha (<15) and low Mach numbers (M < 0.15).
From literature, my Cl and Cd values predict relatively close (10%) to experimental values - but my Cm data (pitching moment) is far out.
I understand that the pressure distribution on the leeward side of the delta wing is going to have a large impact on the Cm value - so if your vortex spanwise location is off - your Cm value will be off as well.
Has anyone working in this field - or could point me in the correct direction or suggest sources for experimental data?
Thanks Riaan
Old   March 9, 2005, 16:28
Default Re: Validation of Pitch moment for subsonic Delta
Jarmo Monttinen
I'm not working on this and don't know of experimental data, but these suggestions came to my mind as alternates:
About which location are you calculating you Cm, and which location does the experiment use? This might be the source of the problem... if not, then look at the Cp-distribution if possible.
-- Jarmo
Old   March 9, 2005, 16:36
Riaan
I took the same position and same non-dimensionalizing value of length...first thing I checked !
2D Airfoil Centre of Pressure, Pitch Moment and Pitch Moment Coefficient aerospain ANSYS 2 May 4, 2020 21:47
Cd of Delta wing chitharenjan FLUENT 4 July 22, 2010 11:12
Plotting Cp vs z-cordinate on Delta Wing Shamoon FLUENT 0 December 31, 2007 10:31
Delta wing Pitching moment Riaan FLUENT 1 March 15, 2005 02:07
Delta Wing Structured Grid Riaan FLUENT 3 December 31, 2004 13:03
