December 1, 2011, 15:54 |
#21 |
JPConway
Rep Power: 15 |
ok i see where you're going. for those that might be following, here's where blackjack is pointing me (i think)
Mz,cp = Mz,o + (o-cp)xFo = 17 + (0-0.28,0-0.016)x(-3.48,60.65) =0.07368Nm blackjack, how were you able to get yours down to 1 microNm? would you expect the results of Cp to be the same if the moment was measured from another location? |
December 5, 2011, 18:37 |
#22 |
JPConway
Rep Power: 15 |
hi, just checking in since removing that spam from the thread. any comments blackjack or others?
December 5, 2011, 22:23 |
#23 |
james nathman
Rep Power: 15 |
rounding-off x by .001 changes the moment by 0.060 Nm.
32-bit precision works for me. If I stand just right on the bathroom scale, I can have dessert. Likewise, if the forces are measured at a different location, they won't be the same. Hence the CP location will change. I also envision someone constraining y=0 for an airfoil near zero lift. GIGO. The less tolerance you have for slop, the less sloppy you can be. It's late. G'day. |
February 9, 2021, 02:43 |
Help needed for finding Cop
#24 |
Ashish
Hi CFDers!!
i am using star ccm+ for simulating my Aerodynamics on car. but i could not find a proper way to find the Cop of my car. Can someone tell me how to find the Cop. Thanks. |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 12:35 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 18:19 |
custom pressure field at the faces | Souviktor | FLUENT | 0 | April 3, 2009 09:09 |
Pressure wave pattern over body in steadystate? | Chebeba | CFX | 1 | March 16, 2008 03:00 |
