conjugate gradient method
Old   March 2, 2005, 20:05
Default conjugate gradient method
parth
can the conjugate gradient method (iterative solver) be applied to unstructured grids ,
i wish to use it to calculate pressure correction on unstructured grid. any suggestion
Old   March 11, 2005, 14:08
Default Re: conjugate gradient method
Bryce
Yes you can use a conjugate-gradient method on unstructured grids. If you use a Jacobi preconditioner then you can use this method without creating the sparse matrix as you only use information from a cell and its immediate neighbours.
Try checking out "Templates for the Solution of Linear Systems: Building Blocks for Iterative Methods". It's available for free on web as does a good job explaining the conjugate-gradient methods.
Pre-conditioning conjugate gradient method. Prashanth Main CFD Forum 0 October 17, 2007 14:52
conjugate gradient method for linear equations brian Main CFD Forum 1 March 5, 2007 09:27
Conjugate Gradient Method P.kalyanakumar Siemens 1 August 1, 2005 08:36
SIMPLE Algorithm & Conjugate Gradient Method Abhijit Tilak Main CFD Forum 7 March 20, 2001 01:01
Poisson eq and conjugate gradient method Gary Dantinne Main CFD Forum 2 March 19, 1999 01:24
