Muffler flow analysis
Old   March 2, 2005, 08:53
Default Muffler flow analysis
vatsa
Hi all
I did a preliminary Muffler CFD using both star-cd and cfx. I modelled the exhaust pipes, muffler(perforated, reactive type) and the tailpipe to considerable detail
I assumed Steady state, incompressible, turbulent flow scenario of homogeneous fluid(air ideal gas instead of exhaust gas). heat transfer was ignored
At inlet(after sufficient distance from the turbo), velocity/mass flow rates are known
preliminary analysis revealed that velocity at tailpipe equal to that of the inlet.(which may not be realistic)
I want to know how to define the BCs, what are all to define so that my simulation is realistic?
please let me know whether 1) my assumption of steady state is valid? 2) my assumption of incompressible is valid? 3) the order of magnitude of temperature and velocity of exhaust gases when issuing out of tailpipe..for a typical 6 cyl diesel engine
thanks and regards srivatsan
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
Steps for analysis of a flow rskrishna87 CFX 15 February 1, 2011 12:08
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
how to do this blade passage flow analysis ? manish CFX 2 January 16, 2006 04:58
Flow analysis of vane pump Loganathan FLUENT 4 September 4, 2002 05:51
